Go Back   Automotive Forums Car Chat > Nissan > 240SX | Silvia | 200SX(RWD) | Gazelle | 180SX
Old 12-18-2005, 04:54 PM
therealrayman's Avatar
therealrayman therealrayman is offline
Send a message via AIM to therealrayman Send a message via Yahoo to therealrayman
z32's
i'm thinking of hitting up my local junker for some calipers/rotors/and brake lines off the 300, but what year should i use for my 90?
Thanks guys.
Also, anybody selling mirrors (auto or manual, idc) to fit my 90'? I have no glass on either side :P.
2002 Ninja 250R = Franken-Bike after someone hit it parking and left it there .
1990 Nissan 240sx XE
-Newly machined head just put on.
-Will be back on the street soon...
"My car won't start, what should I do?"
"Did you check your headlight fluid?" <<LOL, I love it.
Old 12-18-2005, 05:39 PM
TRUBO_89's Avatar
TRUBO_89 TRUBO_89 is offline
Re: z32's
read this
very informative about every thing
http://importnut.net/300zxbrakeswap.htm#compare
"I wish there was a knob on the TV to turn up intellegence. There's a knob called "brightness," but it doesn't work." -Gallagher
still need a car...so sad
Old 12-18-2005, 07:37 PM
D-Bo's Avatar
D-Bo D-Bo is offline
Re: z32's
z32 is 90-96 300zx.. so anything from those years. check out www.z31.com to see what kind of brakes they had.. i don't think they're anything special but they might be..
Originally Posted by iVteC_PoWeR
to me when i really look at it hondas just too expensive and theres not much power even after you spend loads of money...
http://www.cardomain.com/id/dbo240
***LOOKING FOR A COUPE, ENGINE IS NOT AN ISSUE***
Old 12-18-2005, 08:40 PM
AWDSR20 AWDSR20 is offline
Send a message via AIM to AWDSR20 Send a message via MSN to AWDSR20
Re: z32's
Thanks guys.
why?
"A good driver is measured not by his lap times, but by the amount of time he spend trying to make sense of his car"
E.K.
Old 12-20-2005, 01:56 PM
D-Bo's Avatar
Re: z32's
whynot
Old 12-21-2005, 01:54 AM
Re: Re: z32's
Originally Posted by D-Bo
whynot
do u have a 280+ hp motor?
do u go to the track?
do u do a llot of down hill racing?
did u mode the stock unit... they work fine if u add some good lines and pads...
i like my Z32... but then again i USE them... (track..etc)
2cnts
E.K.
Old 12-21-2005, 10:34 AM
Re: Re: Re: z32's
2cnts
maybe all of us don't modify our cars just for the track all of the time, i like to work on cars because i find it enjoyable, not to run it on the track. i thought the extra breaking power would be a nice addon condsidering i have plenty of junkers nearby. Plus, i can find the z32 parts nearby for around 100.00, can you find an sr20 that cheap? Didn't think so, we don't all have a grand to drop on parts, kinda hard to save when all your money goes to bills ; ).
Old 12-21-2005, 03:02 PM
D-Bo's Avatar
Re: z32's
i wouldn't completely agree with you, therealrayman, but then again i don't completely agree with awdsr20.. i've got them on my car and i'd say they come in handy when i'm driving around with the other north eastern ontario 240s (check out our website www.neo240sx.ca)..
Old 12-21-2005, 03:50 PM
57r337.Dr1f73r's Avatar
57r337.Dr1f73r 57r337.Dr1f73r is offline
Send a message via AIM to 57r337.Dr1f73r
I take it you've found that pesky gov in 5th D-Bo, its kinda nice knowing you have great brakes when your goin that fast.
Seatbelts saved my life
Old 12-21-2005, 06:13 PM
D-Bo's Avatar
Re: z32's
that was when i was on my way home from montreal last summer, i was following a 300C.. highways here are great, safe enough for high speeds.
Old 12-22-2005, 01:11 AM
Re: z32's
don't know ... i had asixx pads and stop tech lines + rotors and it worked fine... stopped well " btw i have the ABS calipers... there are bit bigger"
i got the Z32 bcus i worped my rotors right away on my 1st track day... Z32 4 pistons brakes apply even amount of pressure on each pad, hence making the contact surface with the rotor even to produced a flush pad wear and a solid pedal feel under high stress.
the stock "floater" unit, with its SINGLE caliper would literally BEND the pad and decreases the contact surface+ generate allot of heat + worp the rotor instantly..
if u fined them for $100 get them i guess.
E.K.
