Go Back   Automotive Forums .com Car Chat > Chevrolet > Lumina
Old 12-18-2005, 05:48 PM   #1
wyley187
rotten egg smell in 91 lumina
i Have a 91 lumina that has recently started hesitating after warming up or idling for 5-10 minutes and there is a horrible rotten egg smell after driving for about 5 miles plz help
wyley187 is offline   Reply With Quote
Old 12-18-2005, 08:32 PM   #2
jeffcoslacker
Lactose the Intolerant
jeffcoslacker's Avatar
Re: rotten egg smell in 91 lumina
Your catalytic convertor is on it's way out.
You made three mistakes. First, you took the job. Second, you came light. A four man crew for me? F**king insulting. But the worst mistake you made...
...empty gun rack.
jeffcoslacker is offline   Reply With Quote
Old 12-18-2005, 09:19 PM   #3
maxwedge
A990 racer
Could be a problem with coolant temp sensor staying in the cold range, this may not set a code and would cause a rich mixture, could cause some cat odor, another possiblity here, but less likely than the cat. A scan will reveal if the temp sensor is accurate.
maxwedge is offline   Reply With Quote
Old 12-19-2005, 09:37 PM   #4
wyley187
Re: Re: rotten egg smell in 91 lumina
I should add that I jumped the obd and its coming with with two codes lean exhaust and rich exhaust could this possibly be the o2 sensor????
Old 12-19-2005, 10:24 PM   #5
meistermind
Survey Says.......Catalytic Converter!
Could be this....or could be that!. Lets face it, you have a '91. Smart money is on the Catalytic Converter!!!
This is the one, go get it. It bolts right up to the existing pipe joint flanges (unless already modified):
http://www.partsamerica.com/ProductD...pe=248&ptset=A
Just Do It!!!!!!!!!!
meistermind is offline   Reply With Quote
Old 12-19-2005, 10:26 PM   #6
meistermind
Re: Survey Says.......Catalytic Converter!
OOPs!! Wrong Link. Here it is:
http://www.partsamerica.com/ProductD...pe=145&ptset=A
