Old 12-18-2005, 03:44 PM
a7x278 a7x278 is offline
87 s10 blazer no start
just did the starter on it then 2 days later theres no start. it will crank but wont start. the cat is clogging up but i dont believe that would stop the motor from starting... any suggestions?
Old 12-18-2005, 06:22 PM
GTAfanatic GTAfanatic is offline
Re: 87 s10 blazer no start
is there fule at the carb/TBI? while tring to start it?
let me know PM if you want
Old 12-18-2005, 06:31 PM
MagicRat's Avatar
MagicRat MagicRat is offline
Nothing scares me anymore
Check the basics. If it has a spark and fuel, it should run.
Old 12-18-2005, 08:46 PM
Crasen Crasen is offline
Try checking for spark, you can remove a spark plug and lay it on the enginewith the threads touching metal for a ground and watch it while someone tries to start it. If you do not get a spark your problem is ignition related. if you do get a spark (I am assuming it is fuel injected and not carbureted) remove your air filter and watch the fuel injectors while someone tries to start the engine. If the fuel injectors do not spray fuel you have a fuel system problem. hopefully that will send to in the right direction. Depending on how much the exhaust was restricted it would be possible to keep it from starting, but unless you had a substancial power loss, or an overheating engine I would look into other area first. btw did anything start to go wrong before this or was this an all of the sudden problem
Old 12-19-2005, 01:01 PM
so did you fig out the problem?
Old 12-19-2005, 06:17 PM
no ive been workin and havent had a chance to look at it really.. im gunna check the spark probably tomarrow and cut the cat off too
