Go Back   Automotive Forums Car Chat > Ford > Contour
Old 12-18-2005, 02:56 PM
tjscarts tjscarts is offline
96 Contour SE
My wifes 96 Contour runs rough at idle or stalls. It does it during cold start, surging up and down, then levels out for a while then even warm, it will surge and stall. Each time she takes her foot off of the pedal, the idle will drop and the engine will stall. I have changed the TP sensor and no codes are logged. In fact, the service engine soon lamp is burned out cause at no time does it light up. Save that for another day!! Scanner says no codes!
I have found broken vac lines, most of which were brittle plastic, some were rubber.(Bloody Fords)...and I work for Ford Michigan Truck! It seemed the more I dug around the more the lines fell apart. Fixed all I could find that were bad.
Seems the problem will go away for a while then come back. I sprayed start fluid around and found it smoothed out out the idle when I sprayed around the upper intake manifold.....
Is it common for these intake gaskets to go bad?? Thanks, TJSCARTS
OOPS...96 Contour SE 2.5 V6 stick
Old 12-18-2005, 03:34 PM
beyondloadedSE's Avatar
beyondloadedSE beyondloadedSE is offline
AF Ford Contour-Advisor
IAC.
how to replace it. How to taken off contour.org.
http://www.contour.org/FAQ/FAQ.php?s=probs&displayid=7
"The CEG Nazi"
www.contour.org
1996 Ford Contour SE - Sold
3.0L V6 and Arizona Dyno Chip Turbo Kit
364 whp, 410 wtq @ 16 psi and only 4,700 rpms.
1999 Tropic Green SVT Contour - Bone stock and MINT
