Go Back   Automotive Forums Car Chat > Honda > Let's get Technical!
Let's get Technical! Discussion for hardcore in-depth motor heads!
Old 12-18-2005, 02:43 PM
natecivic92's Avatar
natecivic92 natecivic92 is offline
Fuel Tank
I have a 92 civic.the problem is i have a bunch of caked up rust in the tank.it hasnt wen't through and looks like i left the cap off is there any way possible to clean it.
Old 12-18-2005, 03:34 PM
civickiller civickiller is offline
Send a message via AIM to civickiller
Re: Fuel Tank
i would recommend getting a new tank.
Team Lonely Drivers
Old 12-18-2005, 06:22 PM
Schister66's Avatar
Schister66 Schister66 is offline
AF -Advisor
Send a message via AIM to Schister66 Send a message via MSN to Schister66
Re: Fuel Tank
i would get rid of that tank....a new tank is a lot cheaper than a new engine...
2015 DGM STi - 2006 SGM STi - 1999 Built/boosted GSR
Old 12-19-2005, 08:32 AM
Re: Fuel Tank
its a hassle to clean a tank really good. then you gotta worry about all the rust and the damage it might have done. then you gotta worry about fixing it. its a hassle. if you got the time then clean it out and fix it. if not then buy a new one.
of course this depends on how heavily its rusted
Team Lonely Drivers
Old 12-19-2005, 01:33 PM
Re: Fuel Tank
It is not really that bad and I have time.I was just thinking is a certain kind of solution like a fuel treatment or part cleaner.I have taken the tank off before it is sort of easy the tank goes for like 130 bucks and any money i can save around the hoiliday
is needed
Old 12-19-2005, 01:54 PM
CivicSpoon's Avatar
CivicSpoon CivicSpoon is offline
There is no Spoon
Re: Fuel Tank
There is no easy or cheap solution. You either replace it, or take your chances of having to pay even more $ for the damage it will do. If you're going to take your chances, NEVER let your tank go ¼ of a tank or less full. You let it get low once and say good bye, to at the very least, your fuel pump. I had an oldsmobile that had sediment in the gas tank, when I let the tank go ¼ of the way full; the fuel pump over heated and died (happened a few times because I was dumb).
Old 12-19-2005, 04:14 PM
Re: Fuel Tank
thats why he needs to drops the tank and clean it throughly removing everythign in there and all the rust.
Team Lonely Drivers
Old 12-19-2005, 06:01 PM
Re: Fuel Tank
It's sort of like a gravy I will remove the tank,and make sure I get rid of all rusty material .I think i will have to put like parts cleaner in it,swish it around for a while then clean out with a shop rag ,then do the same thing but with gas.Does that sound like it might work.
Old 12-19-2005, 06:38 PM
superbluecivicsi superbluecivicsi is offline
AF - Advisor
that will work, but, it will still rust in time. rust grows like barnacles on rocks.
99 [email protected] psi si- I voted for the Terminator for Gov.
95 HB- B16a2- SC34@12psi
WTB: USDM B16a2 or B16a3 complete short block. pm is the key.
FS: B series InlinePro cast mani, PnH RC 550s, and Hondata S2b. pm me.
Old 12-19-2005, 07:19 PM
Re: Fuel Tank
So it is better to replace because i would have to
do it again in the future.
Old 12-20-2005, 12:13 AM
Schister66's Avatar
AF -Advisor
Re: Fuel Tank
new tank....end of discussion! I wouldn't mess w/ the old rusty one....that's just me tho
Old 12-22-2005, 09:30 AM
gmcuajo gmcuajo is offline
Re: Re: Fuel Tank
Use a new tank... And search if you can use a plastic from a late model...
