Timing off help 98 Chevy Truck
Hi All,
Well a bit of a long story here but here goes. We have a 98 Chevy 2500 gas engine vortec v8 5.3 that the timing is awful. Changed all plugs and wires and rotor and cap so not the problem. Took to the shop the mechanic said he thought the tiiming was off never could get it to line up on the light gun, so changed the gears and they linned out and started it back up, and still has the same problem. About three of the cylinders are misfiring and sound rough. Now it is an injector module not a true injector in the intake. I am at a loss and do not know what the problem is does anyone know what it could be? Mechanic wants to experiment to see what it is but hey it's not his money it is mine......LOL Please help right away if you can....A.S.A.P. |
When you say the timing is "awful" do you mean the engine is missfiring? Did the tech check to see how much slack was in the chain before replacing? Seems like a strange place to start for the fix. Leave all the plug wires loose on the distributor cap, start the engine and raise the rpm to 1500. Use some insulated pliers and lift each wire off one at a time to see if you can determine which cylinders are missfiring based on the rpm change or shaking of the engine. RPM drop or excessive shaking indicates that cylinder is contributing. You can put small pieces of vacumm line in series with the wires to cap and short the cylinder out with a test light if you are afraid of getting zapped. I would perform a compression and leakdown test and check fuel pressure. You could also put a vacuum gauge on the intake and check manifold vacuum which can tell you alot about the internal mechanical condition of the engine.
Re: Timing off help 98 Chevy Truck
Thanks for the feed back will check as you indicated above and as far as the chain goes he never could get it to line up at all with the light and knew it had slipped two or three links and yes there was some slack on the chain as well.............At 189 k seems possible of wearing out a bit but now that it is linned up and the timming light is square it still misfires on three cylinders. I will ask if he checked on this end as you quoted above. another question I have is the fuel sensor or the o2 sensor could this have anything to do with it as well? I read other places it could and was wondering if you have experience with this as well. Thanks for you help on this! |
Re: Re: Timing off help 98 Chevy Truck
The "timing" on the 96 and up GM V8 Vortec engines cannot be adjusted or set using a timing light. To set the proper position of the dist, you must use a bi-directional scanner to set Camshaft Postion Offset. Next it sounds like you have a missfire, have you checked and verified compression, spark and fuel on this engine?
Why do you never have enough time or money to do the job right the first time, but enough time and money to do it again? Got all the certifications 25 years ASE Certified Master Technician GM WCT Yea..I work at a DEALERSHIP....got a problem with that? Want to diagnose cars like the Pros? FOR SALE: OTC Perception 2 channel Labscope (badged as a Matco Reality) This is my personal labscope that I use to diagnose waveforms, like new, comes with leads and training video PM Me for details |
