Go Back   Automotive Forums Car Chat > Toyota > Sienna
Old 12-18-2005, 10:35 AM
sjw2 sjw2 is offline
Unhappy Break light comes on while turning 2000 Sienna
Whenever I turn my 2000 Sienna, break light comes on for 1-2 secs and then goes away by itself. It happens more on right turn.
Please help.
Thanks
Old 01-04-2006, 06:55 PM
aldovera aldovera is offline
Re: Break light comes on while turning 2000 Sienna
Check tour brake fluid level, it might bd low.
Old 01-17-2006, 12:44 PM
Doug Tatham Doug Tatham is offline
I'm not a mechanic, but another thing that might be causing a problem is that your ABS monitors the rotational speed of your tires (This is also how it checks tire inflation pressure) and when you go around corners your tires rotate at different speeds. How fast were you cornering and could the fluid have sloshed to one side of the reservior? Do you have different tires on front and back? If your tire inflation light also stays on, check to see how good a match your tires are.
