Old 12-18-2005, 10:05 AM
patoffspyder patoffspyder is offline
Badger 360 needle size?
Hi guys!
I am wandering what is the size of the needle on the badger 360? The only information I can get is "Single size nozzle"
I need this info in order to know how much I need to thin some kind of paint.
Thanks for your help!
Old 12-18-2005, 03:18 PM
LS1Aaron LS1Aaron is offline
Re: Badger 360 needle size?
Needle size does not make a difference really ,thinner paint should be compensated for by psi not needle size.But to answer your question I would say its equal to a medium .
Old 12-20-2005, 05:21 AM
hawkone hawkone is offline
Send a message via AIM to hawkone
Originally Posted by patoffspyder
Hi guys!
the needle size is a fine to large universal needle the further back you pull the wider the spray or use as a single action just pre set the needle then push the button for air its the only brush that i use now thats after an old and new badger 200.
hope this helps
Old 12-22-2005, 10:19 PM
VI Boost VI Boost is offline
Re: Re: Badger 360 needle size?
http://www.bearair.com has all of the technical info and specs an tons of airbrushes so i'm sure you will be able to find it there.
