Old 12-18-2005, 10:36 AM
POSTahoe's Avatar
POSTahoe POSTahoe is offline
Blinking "Service Engine Soon" Light in 97 Tahoe
So I have this Tahoe, but its become a real pain in the wallet, so I went out and bought an Isuzu Diesel pickup just to have something reliable, because the Tahoe surely isn't. Among it's long list of problems, recently the "service engine soon" light has started blinking. It was on already, but that was just an O2 sensor. I know that the blinking means that its a "misfire condition", but I was just wondering if anyone else has had this problem so I dont' replace my entire ignition system if I don't have to. Any help would be appreciated.
97' 2 Door Tahoe Z71
85' Isuzu Pup Diesel (my only reliable vehicle)
"The wise man knows that he knows nothing at all"
Old 12-18-2005, 10:49 AM
GMMerlin's Avatar
GMMerlin GMMerlin is offline
I know stuff
Re: Blinking "Service Engine Soon" Light in 97 Tahoe
Well lets start with some basics.
Do you feel the misfire?
If so when?
The ignition system is 1 of 4 parts you need for proper combustion to take place.
A faulty O2 sensor can cause a misfire by changing fuel trims.
Why do you never have enough time or money to do the job right the first time, but enough time and money to do it again?
Got all the certifications
25 years ASE Certified Master Technician
GM WCT
Yea..I work at a DEALERSHIP....got a problem with that?
Want to diagnose cars like the Pros? FOR SALE: OTC Perception 2 channel Labscope (badged as a Matco Reality)
This is my personal labscope that I use to diagnose waveforms, like new, comes with leads and training video
PM Me for details
Old 12-18-2005, 10:53 AM
POSTahoe's Avatar
Yes, I can definitely feel the misfire, its very noticeable at low rpms, especially when I come to a stop. It's not so noticeable at high speeds. Sometimes it wont misfire at all, but lately, it wont stop misfiring... maybe that will help...
Old 12-18-2005, 11:04 AM
GMMerlin's Avatar
I know stuff
The next thing is to determine which cylinder is misfiring.
You can do this by removing one plug wire and see if the engine performance changes.
The cylinder that does not have the change is the cylinder that is misfiring.
GM WCT
PM Me for details
Old 12-18-2005, 12:16 PM
POSTahoe's Avatar
Ok, so I just drove it around town for a bit to see if it would do it again, and, of course, it didn't do anything, just a constant "service engine soon" light. I recently replaced the plugs less than a year ago. I think I replaced them with bosch. I called my dad and he says that bosch plugs are known to be bad...?? If it's not the plugs, then maybe it is the O2 sensor??
Old 12-18-2005, 12:38 PM
tykrz's Avatar
tykrz tykrz is offline
when that light is flashing, it's something you want fixed ASAP or you risk damaging the engine or the cat's
Old 12-18-2005, 12:57 PM
POSTahoe's Avatar
Yea... that's what I hear, I had to drive it about 30 miles in that condition last night. I'm not going to drive it anymore, I'll just stick with old, ugly, and reliable (p'up) until I can remember why I bought the tahoe in the first place.
Old 12-18-2005, 07:08 PM
tykrz's Avatar
Being a 97 model, I'd change out the dist cap, rotor, plugs (I'd put back in OEM) and plug wires along with fuel and air filters and PCV valve. That takes care of basic tune up work which at that age it more than likely needs anyway. Then I'd go from there. Make sure the basic mechanicals are ok ( ie : no vacuum leaks, etc) before you get carried away going into the electronics of it.
Old 12-18-2005, 07:39 PM
Crasen Crasen is offline
Re: Blinking
You might want to try going to an autozone or another parts store when they are not that busy and have them read the code, it will probably tell you which cylinder is misfiring, it makes troubleguessing a lot faster. But new plugs and wires couldn't hurt, does it misfire when it is wet outside, good indication of plug wires. Plug wires really do not last that long, they ussually do not last as long as spark plugs, even though people ussually replace plugs more often then wires, that's because they are so cheap
Old 12-19-2005, 06:41 PM
POSTahoe's Avatar
Yea, honestly, I have changed the plugs recently, but not the wires, I never knew they didn't last as long as the plugs... One thing I've been pondering on is that for a long while now, I've been driving it (well... I hardly ever drive it) with the O2 sensor faulty. Somebody told me that there's a possibility that since the sensor was out, the injectors are pumping excess gas and the carbon is in turn fouling up the new plugs, causing them not to work... Just a thought. I know what I need to do is bite the bullet and replace the cap, rotor, plugs, wires, and get a new O2 sensor... I just didn't want to spend all that money because I have bigger problems... like a bad torque converter and a bad AC compressor, along with needing new tires and just recently spending over $800 on new ball joints. Not to mention my stereo has stopped working and that's almost the most important thing : ) and I'm still making payments (but only 5 more to go and it's mine!)
Hopefully, after all that is taken care of, it will once again be a reliable beast for a little while.
Thanks for all the input guys
