Go Back   Automotive Forums Car Chat > Chrysler > LHS
Old 12-18-2005, 09:08 AM
dolittle dolittle is offline
94 LHS intermittent starting problem
MY son has a 94 lhs and intermittently it won't start. Some times it doesn't have power to the b terminal at the coil. I've switched out the ASD relay and the cam sensor. It seams to be point to the PCM but I'd like more opinions before I buy one. The car has no codes.
Thanks!
Old 12-19-2005, 11:24 AM
AWP9521 AWP9521 is offline
Re: 94 LHS intermittent starting problem
May be an ignition switch problem, one of the accessory contacts bay be going bad in the switch.
Old 12-20-2005, 06:45 PM
Thanks
Thanks! AWP I'll check that out.
Anyone else have an opinion?
Old 12-20-2005, 09:39 PM
theFREAKnasty82's Avatar
theFREAKnasty82 theFREAKnasty82 is offline
check also your battery connections, make sure they're clean and tight. Also, check your battery, make sure it's not too weak.
Daily Overhauls Do Get Expensive
Dangerous On Days Gears Engage
Dead On Day Guarantee Expires
Dead Or Dying Gas Eater
Department Of Defense Garbage Equipment
Dodge Owners Don't Get Excited
Don't Overdrive Gutless Engine
Drips Oil Drops Grease Everywhere
1995 Dodge Dakota SLT 3.9 V6
1995 Jeep Grand Cherokee Laredo 5.2 V8 4X4
