Old 12-17-2005, 11:09 PM
Viper_Storm's Avatar
Viper_Storm Viper_Storm is offline
Send a message via AIM to Viper_Storm Send a message via MSN to Viper_Storm
Minor Problem, 96 Cav
for the climate controls, the fan control thing, it has 4 settings like low, low-mid, mid-high, and high, but only high works, how can i fix this?
All Throttle, No Bottle!
Torque Makes You Go... FAST!
Horsepower Is For Braggin Rights.
Money talks, But all mine ever says is Goodbye
~Viper
"twospirts" / "TS" - Definition: Obsolete
Old 12-18-2005, 03:34 AM
CCLaguna CCLaguna is offline
Send a message via AIM to CCLaguna Send a message via MSN to CCLaguna Send a message via Yahoo to CCLaguna
Re: Minor Problem, 96 Cav
Yeah, I have an '01 and the only time I hear air coming out is when it's on the 3rd line and 4th line...if it's on 1 and 2, it's basically doing nothing unless your doing 80 MPH+, then it lets air come in.
Yes, i'm new to the car world. No, i'm not dumb.
Add Yourself To The Map AF Members!
Old 12-18-2005, 08:04 AM
JimofWare JimofWare is offline
use the search on this forum you will see that this has been asked a bunch... the likely cause your blower motor resistor in your search you can find out where it is, tricks on getting it out, and even how much it costs...
Old 12-18-2005, 10:46 AM
mike2004tct's Avatar
mike2004tct mike2004tct is offline
been there, done that....
It's the blower motor resistor, located under the passenger dash. It's best if the passenger seat is removed while attempting this repair, unless you're a contortionist.
Remove the kick plate under the dash, disconnect the wire harness from the blower, remove the blower(3 screws), then remove the harness to the resistor board, now remove the resistor board(2 screws, one is very hard to access). A $25.00 item at most parts stores.
Old 12-18-2005, 12:50 PM
Re: Re: Minor Problem, 96 Cav
so this will cause 3 of the 4 settings not to work?
1 & 2 never did anything but 3 was just right, and 4 is just to much, but now 3 does nothing and 4 still works like normal.
and btw i will be there all day searching since i dont even know what the hell im searching for.
~Viper
Old 12-19-2005, 08:09 AM
Re: Re: Re: Minor Problem, 96 Cav
If your blower only works on HIGH, the resistor board is your problem.
The blower motor only has 1 speed (HIGH), the resistor reduces voltage to the motor in 4 different steps, reducing the speed of the motor. This is why you experience different settings disappearing at different times.
You have 4 selections on the switch, and when the switch is off, the fan motor still runs to circulate air at a very low speed- this reduction is usually the first one to go because it's constantly on.
Do a search on the top page of this forum for "blower resistor". You'll get a least 25 returns for the same exact symptoms you mention.
