Closed Thread Show Printable Version Show Printable Version | Subscription Subscribe to this Thread
Old 12-17-2005, 07:53 PM
cleanshavenrsx cleanshavenrsx is offline
Send a message via AIM to cleanshavenrsx Send a message via MSN to cleanshavenrsx
Started the tune up... holy crap...
Well i got the spark plugs in... it wasnt really a bitch just not as easy as plugs should be...
the plugs i pulled out look like they are older than 95 ive never seen a rusted plug before ill post pics of them... dam they were tight... 2 of them were cracked..
i still have a misfire but i didnt get to the wires and distributor cap and rotor...
im def buying an intake tonight! that stock intake is crap the hole is like the size of 2 half dollars.. geeze....
I drained the radiator... it looked like coffee... i have the water and bottle of flush in there now i drove maybe 30 miles so far....
Did the engine flush... put full synthetic mobile 1... with a super tech filter.....i notice a change in oil pressure going to synthetic... no leaks i could see yet... but with my luck there will be....
need to do the tranny!!!!!!!!! i just keep putting it off im an ass!!!!the pan gasket has been leaking onto the exhaust pipe thats the bad smell.. i took it our for a spin i think the tranny ijust going to die with in the week its horrible... it slips into 3rd and 4th.....
is there anthing i missed so i can get better than 4mpg???? im getting bout a 100 to a tank it horrible.....
its killing me.....
Old 12-17-2005, 08:05 PM
Re: Started the tune up... holy crap...
also there is a sludge all over the front.. mostly the transferr case and the steering box.. it looks like it was there for awhile i cant tell where its coming from
Old 12-17-2005, 09:22 PM
drdd's Avatar
drdd drdd is offline
Re: Re: Started the tune up... holy crap...
change that cap and rotor and wires - use the anti-seize on the plugs!!
also, change the pvc, and fuel filter if you haven't already. clean your MAF sensor and Idle Air Control sensor.
have you done your CPI and nut kit yet ?
sludge in the front is probably from the typical, common, "weeping oil" lines. I wouldn't worry about it unless you are losing significant amounts of oil ... usually they "weep" at the crimps a little bit ...
flushed your cooling system lately? change your rad cap to a Stant brand cap!
tune 'er up ... git 'er done!
Old 12-18-2005, 07:27 AM
Re: Re: Re: Started the tune up... holy crap...
i havee a stant cap i picked up yesterday
the radiator flush is in now
howe much is a pvc valve
somethin was done with the feul fo 600 a month b4 i bought it i gotta check... i cant afford that thing thats lik 300
Old 12-18-2005, 09:26 AM
mike2004tct's Avatar
mike2004tct mike2004tct is offline
Re: Re: Re: Re: Started the tune up... holy crap...
pcv - not pvc (positive crankcase ventilation) valves are about $5.00 tops. (plugs into the valve cover, connected to the throttle body with a rubber hose)
DRDD suggests replacing the fuel filter (about $25.00), not the fuel pump (about $300.00)
Old 12-18-2005, 11:49 AM
im talking bout the cpi being like 300 i know the pump is ok
i know where the pcv is i just wanted to know how much.
filter is being done next week
Old 12-18-2005, 12:09 PM
drdd's Avatar
I'm not sure that I'm understanding you correctly. You're sayind that you have not done the CPI / nut kit yet?
If not, that is the reason for your 4 mpg. It happens to nearly all 95s. Your tune up will be a waste of time and $$ if you haven't fixed the CPI problem ... search CPI and nut kit on this forum ... you'll find lots of info ...
you cat convertor is probably dying too depending on how long you've been driving with the fuel problems ...
Old 12-18-2005, 05:31 PM
your not understanding me correctly .....
i said it may have been done something with the feul was done a month ago
Old 12-18-2005, 11:10 PM
dmbrisket 51's Avatar
dmbrisket 51 dmbrisket 51 is offline
Send a message via AIM to dmbrisket 51
if the cpi is leaking, and you continue to drive it, you may have a fire clame to your ins. company, your dumping raw gas into the cats honeycomb, which burns extra hydrocarbons, you can/will catch the carpet on fire inside, best to find out when the cpi nut kit was done
Old 12-19-2005, 10:31 AM
well how do i see if the cpi is leaking? cpi is new to me.all my cars just have fuel rails to injectors...
im waiting for chilton.....
Old 12-20-2005, 12:12 AM
stoney1962 stoney1962 is offline
My mpg's suck just What is a cpi?
Old 12-20-2005, 08:34 AM
central port injection the were the oldversion of the vortec... 95 was the last year...read this whole forum and there will be a link to one that was replaced... reall good pics to help.. the do a search to get the most info you can to find out if thats your prob... its a 300 dollar peice..money i dont have because i have to buy a tranny
Old 12-20-2005, 02:16 PM
tranny= going somewhere, cpi= safly going somwhere, if both items have issues you need to fix both, but the cpi is a safty issue on top of gas mileage and emissons if your state/provence has them
Old 12-20-2005, 04:14 PM
but i dont know if its bad its not gold in there
Old 12-21-2005, 01:03 AM
60+ pounds of fuel pressure, any leak is bad
Closed Thread
