Go Back   Automotive Forums Car Chat > Honda > Interior | Audio | Security
Interior | Audio | Security Tech forum to assist in Honda/Acura Interior, Audio and Security.
Old 12-17-2005, 06:27 PM
dipset1 dipset1 is offline
Cd player problem
My CD player will not play in my 99 integra i have checked all the interior fuses they are all ok I took out my cd player and took off the harness and put my stock cd player in and it still didnt work also the clock in the dash doesnt work... is their anything that i am forgeting to check???
Old 12-17-2005, 09:26 PM
i_a_n112784 i_a_n112784 is offline
Send a message via AIM to i_a_n112784
Are you visually checking the fuses, or using a multimeter? It's rare, but sometimes a fuse can look good while it's really blown. My other thought is that you have a damaged wire, but in a car that new, it is also rare. You might also be able to use a test light to check the fuse rather than visually inspect it. I hope that makes sense, because I've been kinda drinkin and it's hard to gather my thoughts, but believe it or not, I do have a few ASE certs.
Oh, and did you use an adapter harness when putting in your new radio?
Old 12-18-2005, 01:07 AM
InstallTech's Avatar
InstallTech InstallTech is offline
Re: Cd player problem
Yep. 99 percent sure that it's just a blown fuse. The clock and radio functions on most Hondas are run off the same circuit.
I reject your reality, and substitute it with my own.
Old 12-18-2005, 02:09 AM
Yes I have checked them all manually and yes i used an adapter harness when i put in my radio...tomorrow i'll go under the hood and see if i can find which fuse is the radio/clock fuse but i have a feeling its a damaged wire because i took my cd player out because i had a cd stuck in it and when i put it back in it no longer worked but I guess i'll find out later thanks for the help and I'll post again later my results when i find the right fuse
Old 12-18-2005, 02:59 PM
I would like to thank both of you for your help there was a blown fuse however it was in the hood not the interior fuse box I was able to replace it and now everything works so thanks again
Old 12-18-2005, 04:56 PM
No problem. Glad it worked out for ya.
