Go Back   Automotive Forums Car Chat > MG > MGB
Old 12-17-2005, 06:13 PM
Bills 97 Blazer Bills 97 Blazer is offline
MGB valve adjustment
My dad is trying to adjust the valve on his 1971 MGB. Is says in the book he has to adjust 1 when number 8 is fully open, and so on down the list. My question is: as your looking at the front of the motor, are the valves 1,2,3,4,5,6,7,8? I'm used to ichevy small blocks and dentifing them as #1 intake and #4 exhaust and so on.
Thanks, for the help.
Bill
Old 12-18-2005, 12:59 AM
MGBSS63 MGBSS63 is offline
Re: MGB valve adjustment
Bill
From front of head start with 1 ......Number 8 is the last valve on the head so it is 12345678 in a row...make sure you adjust according to manual either hot or cold it makes a difference. Believe It's .015 cold or .013 hot.... mgbss63
Old 12-18-2005, 07:35 AM
Re: Re: MGB valve adjustment
Thanks for info, I appreciate it.
Bill
Old 12-21-2005, 02:37 PM
Flash75 Flash75 is offline
AF - Advisor
The MGB valve adjustment uses the rule of nine for adjusting. Example when valve 5 is open, you adjust valve 4, valve 7 open adjust valve 2 and so on until all valves are adjusted.
FWIW, Clifton
Old 12-21-2005, 09:14 PM
Thanks for "the rule of nine" never would have figured out something so simple.mgbss63
