Go Back   Automotive Forums Car Chat > Dodge > Dakota
Old 12-17-2005, 03:57 PM
birddogman birddogman is offline
Not Idling
I have a 96 Dakota with a 3.9. Today it started with no problem but won't idle. It runs as long as you give it gas but as soon as you let off it stalls. The only way to move it is to powerbrake it to keep it running. It doesn't miss or show any other symptoms. I need help ASAP as this is my only transportation. Thanks!
Old 12-17-2005, 09:57 PM
davida6302 davida6302 is offline
Idle
birddog... I too had some idle problem till I saw on this forum a suggestion to spray some carb cleaner into the carb, worked for me
Old 12-18-2005, 07:59 PM
1thunder 1thunder is offline
Re: Not Idling
yes clean the throttle body bore with a cleaner and a toothbrush and make sure the battery is good and charged up you may have to disconnect the 3 connectors on the pcm for about 15 minutes to reset the adaptive memory also as you won't know if you fixed the problem once the pcm learns the memories for ais and fuel trim
