Go Back   Automotive Forums .com Car Chat > GMC > Yukon
Old 12-17-2005, 04:17 PM   #1
bigdandsoni
Question Help can't find hex for headlight bulb replacement
I have a 2000 Yukon D and I have to replace the low beam bulb behind the battery but I can find the two screws everyone is talking about nor can i do it from the inside Help
bigdandsoni is offline   Reply With Quote
Old 12-19-2005, 02:25 PM   #2
bryfry
There should be two allen head pins pointing straight up above the headlight assembly. Stick a socket over these and remove them. The headlight assy. should come right out.
bryfry is offline   Reply With Quote
Old 12-19-2005, 04:09 PM   #3
YukonGMC
Re: Help can't find hex for headlight bulb replacement
Or two L shaped pins ( per headlight ) that you swing out of the clip that holds them and pull them both up and out. No tools needed. Pull out entire headlight housing then unscrew the bulb socket( half a turn ) that needs the new bulb.
YukonGMC is offline   Reply With Quote
Old 12-21-2005, 11:55 AM   #4
Bevl Hvn
Bevl Hvn's Avatar
lights action
yes the L shape pins swing out 90 deg to remove the whole assembly, the posts with the star shape to them are turned for adjustment. You will need to go get a socket set for these, I got mine at NAPA - not too expensive and hey, NEW TOOLS BABY! Anyways, Use care removing the assembly to not catch the grill and snap something off...
Bevl Hvn is offline   Reply With Quote
