Go Back   Automotive Forums Car Chat > Mercury > Grand Marquis
Old 12-17-2005, 02:33 PM
maxpowers maxpowers is offline
Question 92 mgm NIGHT TIME RUNNING LIGHT FUSE!?!
im adding some fog lights to my 92 mgm and i dont want to flick a switch every time to turn it on, so i want them to turn on when the automatic night time driving lights turn on, but i need find the wire or the fuse. Anyone know how i can wire it up or the fuse # and where its located?
Old 12-18-2005, 10:20 AM
Re: 92 mgm NIGHT TIME RUNNING LIGHT FUSE!?!
ive checked online and have yet to find anything... someone has to know.
Old 12-19-2005, 08:45 AM
Re: Re: 92 mgm NIGHT TIME RUNNING LIGHT FUSE!?!
someone still has to have the mannual or know something about this...
Old 12-19-2005, 10:28 AM
reekor reekor is offline
You will need one replay, use a 12 V 30/40 AMP 5 pin Relay and harness such as ebay item # 5738651658. Hookup the relay trigger (pin 86) to the 12v+ wire of your lowbeam and the other side of the trigger (pin 85) to ground. This will trigger the relay when your lowbeam head lights are turned on. Run a 12v+ wire from your battery with a 15-20amp fuse to (pin 87) of the relay. Then run a wire from wire from (pin 30) of the relay to the + side of your fog lights. Then ground the ground wires of the fog lights and there should be light.
His, 96 Limited, 5.2 Magnum, Magnaflow CatBack System, HID Head & Fog Lamps, 242 T-case swapped , Rear Trac-Loc. Chrome grill added to match the wheels.
Hers, 96 Limited I6, 242 T-case, HID Head & Fog Lamps.
Old 12-20-2005, 10:35 AM
thanks alot reekor! Just one more question. Won't this draw power from the headlight and dim the headlight the wires, or relays, attached to. Pardon my question if it seems dumb but im not much with electrical components.
Old 12-21-2005, 07:25 AM
Re: Re: Re: 92 mgm NIGHT TIME RUNNING LIGHT FUSE!?!
Yes it will draw power from the headlight only to trigger the relay. The relay uses very little power (they can be triggered with a 9v battery) and will not change the load on your headlights.
Old 12-21-2005, 07:43 AM
Re: Re: Re: Re: 92 mgm NIGHT TIME RUNNING LIGHT FUSE!?!
So it'll draw it directly from the battery? I already ordered one and I did some research but just make sure ;0)
Old 12-23-2005, 02:54 AM
Re: Re: Re: Re: Re: 92 mgm NIGHT TIME RUNNING LIGHT FUSE!?!
The fog lights will draw power from the battery, that is why you need to run a wire from the battery with a fuse to the relay. The relay only acts as a switch that is turned on and off by applying power to the head lights.
Old 01-02-2006, 12:04 AM
Thanks alot reekor i wired it up and it works perfectly!
Old 01-02-2006, 04:06 PM
Glad to help.
