Old 12-17-2005, 02:29 PM
Pimpdady753 Pimpdady753 is offline
Commprestion
ok im going to be putting a 393 in my fox body 1990 gt,
kB dished pistons
H-beam super racing rods
twisted edge heads at 58cc
http://www.coasthigh.com/Assemblies/Ford/ford_393w.htm block
not sure on the cam yet
i was woundering what compretion i should run or tell them i need, that would be great thanks.
Old 12-17-2005, 09:21 PM
getstars5 getstars5 is offline
Re: Commprestion
kB dished pistons
first of all, if youve already decided on the pistons, rods, head volume, and block, youve already decided on the compression. the only other thing you can do at this point is to choose what kinda compressed thickness head gasket you want.
check out this site, you may find it intresting: http://www.angelfire.com/fl/procrastination/motor.html
Old 12-17-2005, 10:20 PM
Re: Commprestion
well then what is going to be my comprestion, and is it a good one, lol
Old 12-18-2005, 03:17 PM
Re: Commprestion
what are you gonna do with the car? go to the store? drag? street race? oval? all of this makes a difference. but your compreSION is somewhere around 12-13:1. thats really high. are you gonna turn it into diesel?
Old 12-19-2005, 05:53 AM
SkylineUSA's Avatar
SkylineUSA SkylineUSA is offline
Send a message via AIM to SkylineUSA
Re: Re: Commprestion
LOL, funny
R32 GTR w/351w .020 forged, 8.9:1, PTK T76, Turbosmart 40 BC & 45 WG, Tial 40 BV, AFR 205s 310/245, 228/228 550/550 114 Hydro, 1.7rr, Isky RLs, 4" HKS exhaust, ARC 30x16x4 IC, 8 point cage, C2 gauges, 2 step, C4 3200 stall w/ R Manual & Hurst Ratchet shifter, 17" Panasport G7s, CSU 750 & bonnet, Vic Jr intake, 3.63 gears, Corbeau Carrera seats, Custom wide body, Bomex side skirts and rear 1/4 caps, Tommy Kaira bumper.
Old 12-20-2005, 09:31 PM
Re: Commprestion
no its going to be a week end car\show car\streat race, not so much streat race tho.
Old 12-21-2005, 04:01 PM
351wStang's Avatar
351wStang 351wStang is offline
Re: Commprestion
Shoot for about 11:1 if your going n/a. But you will need to know your compression in order to select a cam.
1969 Cougar
357w & TKO - 475hp
Old 12-22-2005, 05:37 PM
Re: Commprestion
ic, when i get the block and the internals bild i will just need to tell them 11:1 compresion, witch cam should i get then with that compresion.
Old 12-23-2005, 03:26 PM
351wStang's Avatar
Re: Commprestion
call cammotion or comp. a cam company would be able to recomend a better cam for you than I could.
EDIT: I wouldnt go much over 11:1 compression. 10.5-11.2:1 with aluminum heads and a good tune is a great pump gas compression ratio.
1969 Cougar
357w & TKO - 475hp
Old 12-23-2005, 08:13 PM
compression is decided by the parts you use to build the engine. you may need to get a shorter rod to lower comp. or a head with more volume.
Comp cams always seems to be the fav cam. Lunnati cams if you got the money. when you call to select a cam, youll need to tell them hp goal, torque goals, usage, desired powerband, desired redline, sometimes even transmission ratio's. most people tend to cam the engine towards the end of a major build.
Old 12-27-2005, 10:54 AM
SkylineUSA's Avatar
Re: Commprestion
Time to learn
http://kb-silvolite.com/calc.php
Old 12-27-2005, 02:45 PM
Re: Commprestion
should i get a diffent head then, one that is bigger.
Old 12-28-2005, 12:13 AM
SkylineUSA's Avatar
Re: Commprestion
What did you come up with?
Old 12-29-2005, 11:48 PM
Re: Commprestion
i dont know were to find all the number at like
Gasket Thickness
Piston Head Volume
Deck Clearance (in.)
Note: Neg. nubmer above deck, Pos. number below deck
were do i find these numbers at.
and would i better to go with like afr heads.
