Go Back   Automotive Forums Car Chat > Saturn > SC/SL/SW
Old 12-17-2005, 12:43 PM
jimmy4x4 jimmy4x4 is offline
Question rpm's
my saturn is a 96 sw2 1.9 dohc i just bought it cuz my peice of sh*t jimmy died but my question is. my saturn will idol funny when in park it will go up from 800 to 1000 or 1100 and back down it doesn't seem to effect the way it runs. does anyone have any suggestions
Old 12-17-2005, 03:06 PM
shaner123 shaner123 is offline
when your idle is high, get out and pop the hood, wiggle your Throttle Position Sensor wires, if it makes it go down, then thats your problem, get a new TPS connection or try to clean w/ electrical contact cleaner first
also a MUST do in your car is to replace you resin tipped Electrical Coolant Temp Sensor w/ a new one from the dealer, the new one is brass tipped and wont crack like the resin ones, its only about 19 bucks CDN when i got mine, im not sure what they run in the states, but probably around 16ish
there are many many posts about the ECTS, if you goto www.Saturnfans.com and goto the S Series / Tech section there is a really good thread about changing the ECTS w/ pictures, its super easy and probably the one of the first things i would try
Old 12-17-2005, 03:23 PM
the idle goes up and down it doesn't stay up long enough for me to get out and wiggle anything hehehe any way im thinkin a can of bg 44k should do the trick. what do you think?
Old 12-18-2005, 07:55 PM
peppermrj's Avatar
peppermrj peppermrj is offline
Re: rpm's
What's bg 44k? Replace the coolant temp sensor as recommended above.^^^^^^^^^
Old 12-20-2005, 10:18 AM
saturnspeed_12's Avatar
saturnspeed_12 saturnspeed_12 is offline
yeah coolant sensor, and a possible idle air control valve. iac sensors are a common problem on gm vehicles, but i havent heard much on saturns having issues with them.
Old 12-23-2005, 04:25 PM
sickcallawayc12's Avatar
sickcallawayc12 sickcallawayc12 is offline
Re: rpm's
does it constantly do this or just at startup? 800-1100 is somewhat normal for an idle if it's at startup. mine goes up to 1100 on chilly days then goes to 800-900 after it's warmed up.
1998 Chevrolet Blazer LT (95% stock)
Pioneer AVH-P7500 DVD receiver
12" Alpine Type-R in a sealed box
PIAA Super Plasmas GT-X bulbs
PIAA Xtreme White bulbs
K & N drop-in filter
"Melo" and "AI". Enough said.
