Old 12-17-2005, 10:56 AM
PatrickW22 PatrickW22 is offline
Name this part...'92 Cavalier (pics)
Hi, I'm trying to take off the ignition cylinder/switch. Here is the part that is bugging me:
I know theres a 'C' clamp that loosens everything behind it. I have that off. But how do I get this spider thingy off? Please helP!!
Old 12-17-2005, 10:59 AM
dadof4s dadof4s is offline
Send a message via AIM to dadof4s Send a message via Yahoo to dadof4s
Re: Name this part...'92 Cavalier (pics)
I am not sure, but have you tried a hub puller?
Old 12-17-2005, 12:27 PM
ImSoYesterday ImSoYesterday is offline
Send a message via ICQ to ImSoYesterday Send a message via AIM to ImSoYesterday Send a message via MSN to ImSoYesterday Send a message via Yahoo to ImSoYesterday
It appears to be threaded, I doubt a hub puller would be his number one choice of things.
Emily's personal boyslave
TSS: Rockin' the Bitches' Faces.
B16A2 engine with:
Short ram intake.
DC Sport header: Ceramic coated, 4-2-1.
Custom headerback exhaust with disconnected muffler.
MSD Ignition system. (With Enkei wires)
http://www.cardomain.com/id/imsoyesterday
Old 12-18-2005, 05:34 PM
takhani takhani is offline
i thnk i have your answer
So you are trying to take out the ignition cylinder the whole thing you can undo from underneath the ignition and the back the while thing slided in and out there is a pressure pin that releases the whole thin in one kinda like on a vacume hose the metal part i didn't quite understand your question but i think i did if i'm wrong getback to me i do have the answer once i know exactlly what you want to do
Old 12-18-2005, 08:06 PM
unbe unbe is offline
If I'm reading my book correctly you dont have to take that off.And it sounds like there isnt pressure pins when you have a key\switch combo like you have.
1)detach neg bat cable
2)remove tilt lever if equipped remove upper and lower colum covers
3)remove 2ea ign switch retaining screws
4)detach ign sw from steering colum housing and unplug elec conn.
Warning if you have airbags use appropriate steps
Warning #2 I'm just going by book and on my s-10 this same company did not give good ign sw instructions
Old 12-20-2005, 07:49 AM
hi guys, thanks all for the replies. I couldnt figure it out. Basically, somone had tried to steal my car, jamming a screwdriver into the ignition hole. Well my key no longer fits. With my car, it doesnt have the ignition cylinder seperate, it has the switch/cylinder combo, anti-theft thing I guess. I dunno, but a brand new one is $400. Pfft, like I'd pay that. I'm content with a used one for $100. Anyways, thanks all for the replies. I just had it towed to Midas where they'll fix it for me.
Old 12-20-2005, 09:46 AM
cdru's Avatar
cdru cdru is offline
Re: Re: Name this part...'92 Cavalier (pics)
In indeed it does need to come off, I'd disagree. In the last picture you can clearly see that the shaft has splines on it and that the threads have a smaller diameter then the splines. A hub or wheel puller is what you use to remove that.
Autozone has a free repair guide here.
Vinyl adds horsepower, right?
