Go Back   Automotive Forums Car Chat > Isuzu > Rodeo | Passport | MU
Old 12-17-2005, 03:44 AM
travisthumb travisthumb is offline
99' amigo coolant disappears?????
Hi,
I recently started having a problem with my amigo overheating. It started right after I had tromped on the gas to avoid a colission. After tromping I immediately smelled antifreeze. I took it to my mechanic and after testing suggested I replace the thermastat ($165- $15 parts, $140 labor) which I did.
The car ran fine for a few days and then began to overheat again. I took it back and found it was low on coolant. They ran a compression test for several hours to check for a bad head gasket and all the hoses. Everything checked OK. He filled it back up and asked me to keep an eye out for leaks.
Again after a few days the car begain to overheat. Again back to the mechanic and again low coolant. My garage floor is bone dry and they are completely baffled after running an over night compression test and checking for leaks.
His only suggestion and theory is that I have a bad cooling fan clutch that doesn't kick in when the engine gets hot. He thinks I'm losing the coolant through the reservoir hose from when the engine gets hot and blows the coolant out.
After testing it was found that the fan wasn't doing what its supposed to in kicking into high gear when needed. He wants to charge me $220 to replace the clutch but isn't 100% sure it will take care of the problem. This will be $400 spent on an overheating problem with no guarantee that it will be fixed.
Any ideas or healpful advice will be greatly appreciated. Thanks for reading.
Old 12-17-2005, 07:30 AM
surferfletch surferfletch is offline
Re: 99' amigo coolant disappears?????
Look on top of the block, under all the intake stuff and see if you see a puddle between the heads.
Old 12-17-2005, 11:25 AM
Cat Fuzz Cat Fuzz is offline
When you say "compression test" does that mean a cylinder compression test or did your mechanic pressurize the cooling system and check for leaks? If you were losing coolant through the overflow system, your overflow tank would be full and overflowing.
Old 12-17-2005, 05:30 PM
rodeo02 rodeo02 is offline
1998-1999 had a run of cylinder heads that were known to spring coolant leaks. Check for coolant in the spark plug wells. A sure-fire sign of a bad head.
G/luck
Joel
2016 Subaru Forester 2.5i base CVT
2016 Nissan Quest SV
Old 12-22-2005, 01:42 PM
Re: Re: 99' amigo coolant disappears?????
Thanks for your considerate reply. I passed it on to the mechanic and he had checked.
Old 12-22-2005, 01:46 PM
Thanks for the reply. He acually did do both types of test with frustratingly no results. He did find that after running the car for about 5-7 minutes that the resevoir was indeed full which lends credibility to his original thoughts. Thanks for your suggestions.
Old 12-22-2005, 01:54 PM
Thanks for the reply Joel. I did have them look for that as well. After all consideration, we are going to move ahead with the fan clutch. He did give me a price break on the labor so that makes it a little easier to swallow.
G/luck
Joel
