Old 12-16-2005, 02:15 PM
Cold_Silence's Avatar
Cold_Silence Cold_Silence is offline
Send a message via AIM to Cold_Silence Send a message via MSN to Cold_Silence
Question Creaking from steering wheel area?
Hey guys, when im driving thru the city i notice this creaking like noise coming from the steering column/wheel area. Im not sure what it is, its not as bad on the highway but u can still kind of hear it. Its like a creak creak when the road is inconsistent or sometimes on fairly good road. Do you know what it could be? Is it normal, or is it a bearing or something in the steering column? Thanks.
The New Ride!! 2002 Cavalier Coupe..
Originally Posted by noshun
It's a lovely 2200, but got about as much poke as my grandma with no fingers.
www.cleanstartsolutions.com
Old 12-16-2005, 03:58 PM
inatalonIXLR8 inatalonIXLR8 is offline
Re: Creaking from steering wheel area?
Something to do with your suspention. I would guess at either your strut or sway bar linkage. If it's just the linkage, it will only cost around $15 for the part.
95 Talon Tsi AWD 5spd
2.4L4G64 6bolt JE8.5EagleTorqueplatedFully ballanced-balanceshaftARP Ferrea1mm 1Ghead ported/polished HKS264/272 fidanzagears turbonetics copy polished GT3076R VbandTial38mm cometic prothane mounts SARD850 stage4 Compclutch+flywheel 3"exh Walbro255 rewired Innovate wideband O2 ForgeBOV Autronic standalone innovative wideband[url=http://img494.imageshack.us/my.php?image=talonandhelicopter5as.jpg]
Old 12-17-2005, 06:18 PM
vamc's Avatar
vamc vamc is offline
My sister had the same problem with her 97, i would also look at the linkage,and possable lubercate in inside where the grears are.
Old 12-18-2005, 01:47 PM
I found out what it was, its the casing over the dash, it was rattling and hitting the piece under it, so i just put a little paper spacer in between, u cant see it, and sound stopped Thanks anyways.
