Go Back   Automotive Forums Car Chat > Honda > Let's get Technical!
Let's get Technical! Discussion for hardcore in-depth motor heads!
Old 12-16-2005, 01:50 PM
paligap79 paligap79 is offline
Its Cold Up Here!
hey guys,
got a90 teg rs,got CEL 43 fuel supply code,now ive heard that OBD0 doesn't have a 43 code, but i searched it and i typed OBD0 trouble codes and I saw a 43 code there.....anyways,along with this code my car doesnt start in the cold weather, so i got my car towed to my mechanic and it sat out there for a few days, he checked the fuel pressure and he told me that i needed a new fuel pump, so i got one.Got the car back and it sat in the garage overnight......the car started....no CEL's and it was very responsive....then i bring it home and it sits for 3 hours, and it woulldnt start up, so i did some research and found it might be a coolant temp sensor, so i replaced that because it was cheap and easy, still no start, i put my ear right to the pump cover under the seat and turn the ignition on and i hear nothing...i took off my fuel line from the fuel filter and turned the ignition on and got nothing......if anyone has any ideas please share, cause im out of ideas,,,,,,thanks
Old 12-16-2005, 02:13 PM
superbluecivicsi superbluecivicsi is offline
AF - Advisor
Re: Its Cold Up Here!
do you hear the main relay?
cel 43 diagnosis.
http://honda-tech.com/zerothread?id=468260
99 [email protected] psi si- I voted for the Terminator for Gov.
95 HB- B16a2- SC34@12psi
WTB: USDM B16a2 or B16a3 complete short block. pm is the key.
FS: B series InlinePro cast mani, PnH RC 550s, and Hondata S2b. pm me.
Old 12-16-2005, 02:25 PM
i really didnt hear anything, i dont know why my pumy wont engage when its cold out, it makes no sense to me
Old 12-16-2005, 06:42 PM
AF - Advisor
well, if you dont hear the main relay, then, you should test it.
Old 12-18-2005, 08:53 PM
ok ill check that but does anyone know why my relay would work in the nice weather and not in the cold??
Old 12-18-2005, 09:10 PM
AF - Advisor
bad soldering on the relay connections. test the main relay. actually, if you dont hear it near the glove department with the key in the "ON" position, then it has more than likely took a crap on you. test it.
Old 12-18-2005, 09:24 PM
what do i need, a test light or voltmeter or something, and if that is messed up, shouldnt any other systems be affected?
Old 12-19-2005, 08:48 AM
yes i do hear a clicking noise behind the dash, would that be the relay?im just confused why my pump doesnt work in the cold but it does in the nice weather....
