Go Back   Automotive Forums Car Chat > Fabrication & Tools > Metal Shaping and Welding
Metal Shaping and Welding Discuss metal shaping and welding techniques. Share your projects or tips and tricks.
Old 12-16-2005, 10:43 AM
1995 VR4 Spyder's Avatar
1995 VR4 Spyder 1995 VR4 Spyder is offline
Question Best method to flush-mount widebody fenders (welded rear quarters)?
I was wondering if anyone would have recommendations on the best method for mounting a set of widebody fenders. What I have is a car that has welded-on rear quarters like most, and I bought a widebody fender set that does the complete rear quarter front door edge to tail light, and is meant to be attached directly to the quarter.
Would the best way be to drill holes for mounting, use flush-mount rivits, and then 'glass over the mounting points and edges?
Thanks in advance!
- James
1995 3000GT VR4 Spyder
A work/dream in progress....
My VR4 Spyder page
Old 12-16-2005, 03:36 PM
mike@af's Avatar
mike@af mike@af is offline
Captain Over Engineer
Re: Best method to flush-mount widebody fenders (welded rear quarters)?
Depends on the widebody. Some of them actually require a large portion of the 1/4 panel to be removed.
-Mike
Old 12-16-2005, 04:11 PM
Nah. They go right over top of the existing ones:
http://cianciperformance.com/exterior/fenders/3000gt/
http://cianciperformance.com/exterio...rontvclose.JPG
I emailed Cianci and they said that pop-rivits sanded flush is the way they'd done before. I was just wondering what other ways there are to do it? I don't know what to google search on that, I tried "flush mount fenders" and a few other things without much success.
I wanted to avoid drilling holes into the rear quarter panel if possible, since I don't know what's behind it where ... but I don't want a cheesy installation either.
My VR4 Spyder page
Old 12-19-2005, 06:51 AM
mike@af's Avatar
The way we do it with Porsche 944 cup cars is using 3M Adhesive, we usually didnt need to worry about smoothing out. The fiberglass usually breaks before the 3M Adhesive.
-Mike
Old 11-15-2006, 07:42 AM
post post is offline
Hi james have you thought of using body panel adhesive,no rivets to grind off.Just a thought .Good luck with your project. Brad
Old 11-16-2006, 11:19 AM
TheSilentChamber's Avatar
TheSilentChamber TheSilentChamber is offline
Forunn Daberator
Yeah, thats good stuff. There is also a product called Click Bond that works good. The best stuff I have used is called Plexus, its not cheep, but you wont need much. You also have to buy a special applicator for it, I think it sells for around $40 and the glue is about $10 a tube I believe, its been a while sence Ibaught it. Even epoxy laminates will delaminate before the glue comes off. If you have a marine supply place you might find it there, if not you can find it online with a little searching.
