Go Back   Automotive Forums Car Chat > Honda > Let's get Technical!
Let's get Technical! Discussion for hardcore in-depth motor heads!
Old 12-16-2005, 04:28 AM
crabby760 crabby760 is offline
motor SWAP HELP GUYS ASAP!!!!!1
puttin a 96 b18c jdm type r motor in my 95 integra with a ls tranny....
got motor and tranny in car bolted up
pass side axel i go to put it in... and in the hole of the tranny where the axel goes into... bout 2 inches in there this fucking metal bar in the way so the axel cannot slide all the way in...???
any idea what that bar is... its like blockin the passage way of the axel completely
i try moving it but it dont move...
Old 12-16-2005, 06:02 AM
i figured out wat was up with the axels... now i got everything done... suspension put back together.... everything
figuring out that the type r is a 98 obd2... so the wiring is diff...
wat needs to be changed so it will work... so far i fixed distributor i just swapped to my obd1 b16 one.... but anything else that might not be rigth?
Old 12-16-2005, 06:52 AM
civickiller civickiller is offline
Send a message via AIM to civickiller
Re: motor SWAP HELP GUYS ASAP!!!!!1
if the motor is obd2 then your obd1 injector wiring wont fit the obd2 injectors. you can just swap your obd1 injectors over and it will be good
Team Lonely Drivers
Old 12-16-2005, 11:24 AM
CivicSpoon's Avatar
CivicSpoon CivicSpoon is offline
There is no Spoon
Since you said you swapped over to the obd1 distributor, I'm going to assume you're using the OBD1 engine harness. If that is the case, use your stock injectors and swap voltage regulators in your alternator (because 1 plug is square and the other is round). Wire for the extra o2 sensor (if you haven't already). You'll also need an OBD1 to OBD2b conversion harness to plug in the '98 ITR ECU, if you're using it.
Old 12-16-2005, 05:01 PM
WDELOAD WDELOAD is offline
Re: Re: motor SWAP HELP GUYS ASAP!!!!!1
http://www.rywire.com/store/index.php
i did my obd0-obd1 conversion and bought it from here.. great instructions and harness
Old 12-17-2005, 02:13 AM
yup i got a jkobd conversion harness. jasons harnesses are the shit
Team Lonely Drivers
Old 12-17-2005, 03:11 AM
got it in and running.... but when vtec kicks in... i hear like wierd scratchy metal noises? anyideas?
Old 12-17-2005, 05:23 AM
pull off valve cover and check rocker arms to make sure nothing is stratching the cam. also hows the oil level?
Team Lonely Drivers
Old 12-17-2005, 04:06 PM
going to check all that today....
also im sure the headgasket is no good... smokes crazy white smoke... and if i let it sit and idle it will start to GET HOT
i do not know how to change a headgasket though..... how much do u t hink a shop would charge?
Old 12-17-2005, 07:21 PM
i cannot get the rear motor mount to line up rite.... any easy way to do this?
Old 12-17-2005, 08:43 PM
CivicSpoon's Avatar
There is no Spoon
Try putting in the rear mount first, then the passenger side and then the drivers side. This has worked the best when I've helped my friend do swaps. As far as I'm concerned, it's the easiest mount to get in. You just have to take a pry bar, pry it forward and have someone else jack the engine up slowly into place.
Old 12-17-2005, 08:53 PM
yup rear, passenger, then driver
Team Lonely Drivers
Old 12-17-2005, 10:22 PM
thanks guys that worked great... got it in
curious what is code 6 and 7.... my car is throwin those 2 codes?
and if it has them codes what can go wrong? can it damage my motor?
Old 12-18-2005, 12:32 AM
superbluecivicsi superbluecivicsi is offline
AF - Advisor
check your water temp sensor and your tps.
as far as the head gasket goes, do a compression test (hints:this should be done on all new swaps ).
over heating.....................check your cel 6.
white smoke is common with new swaps. its cause alot of moisture builds up from just sitting there.
a compression and leakdown should confirm other wise.
99 [email protected] psi si- I voted for the Terminator for Gov.
95 HB- B16a2- SC34@12psi
WTB: USDM B16a2 or B16a3 complete short block. pm is the key.
FS: B series InlinePro cast mani, PnH RC 550s, and Hondata S2b. pm me.
Old 12-18-2005, 01:41 AM
how do i check cel 6 and 7?
curious
