Old 12-16-2005, 12:43 AM
2poor2tune's Avatar
2poor2tune 2poor2tune is offline
Send a message via AIM to 2poor2tune
can i get a size please
i need to know the size of a zc clutch. i dont know the year of it so could you just give me the years and the sizes. thanks
Old 12-16-2005, 06:48 AM
Hybrid1990crx's Avatar
Re: can i get a size please
doesnt matter on the year of the motor. it matters on the year of the tranny.
this should help you.
Old 12-16-2005, 06:54 AM
1PhatCX's Avatar
1PhatCX 1PhatCX is offline
not only the year of the tranny but the year of the flywheel as well, as the 90-91 has a larger bolt pattern
Old 12-16-2005, 08:31 PM
larger bolt patern? I think not. wouldnt that mean the cranks are different then?
Old 12-16-2005, 10:25 PM
1PhatCX's Avatar
its right in the pic u posted too
i wish i had an 88-89 pressure plate and a 90-91 still to show the difference, try to bolt an 88-89 pressure plate to a 90-91 flywheel, physically impossible, the 90-91 is a larger bolt pattern
even tho its a 12mm difference.. its still a big difference
Old 12-17-2005, 01:39 AM
2poor2tune's Avatar
alright. thanks alot guys
Old 12-17-2005, 02:19 AM
civickiller civickiller is offline
Send a message via AIM to civickiller
if you are going to buy a new flywheel and clutch then the only thing that matter is the # of splines on the tranny
Team Lonely Drivers
Old 12-17-2005, 05:55 AM
derek, did you read the entire thing? Look at the bottom "you can upgrade to 90-91 clutch by using the 90-91 flywheel." Case closed. The flywheel itself is larger, not the bolt pattern. like i said before, if the bolt pattern is bigger than the crank would be different.
Old 12-17-2005, 06:18 AM
1PhatCX's Avatar
i didnt say anything at all about the crank now did i?
re-read what i said... the PRESSURE PLATE is bigger meaning it bolts up on a different spot on the flywheel. meaning the bolt pattern on the flywheel is different
Old 12-17-2005, 06:23 AM
LMAO, way to edit your post, derek. before it said the "bolt pattern for the flywheel", not the pressure plate. its rather obvious that the pressure plate is going to be different with the larger flywheel. And to think i was starting to like you....not that, that matters at all.
look at me editing my old post, and it not saying that I did.
Old 12-17-2005, 06:28 AM
1PhatCX's Avatar
where does it say i edited my post? i didnt edit fuck all pal.
ur just pissed because u know im right
Old 12-17-2005, 06:34 AM
lol since they changed the forum set up it doesnt say anything about editing posts.
You were wrong, admit it, you are being very immature now.
Jeez, wow, look I edited my previous post, and you know what, im editing this one as I type this.
Hows it feel?
Old 12-17-2005, 07:03 AM
FuLL BLown STD's Avatar
FuLL BLown STD FuLL BLown STD is offline
Send a message via AIM to FuLL BLown STD
Re: Re: can i get a size please
[quote=Hybrid1990crx]LMAO, way to edit your post, derek. before it said the "bolt pattern for the flywheel", not the pressure plate.
dude i agree man.. i seen it lastnight.. derek u lil fag humper u did edit.. who cares no1's perfect.. sumtimes ur wrong sumtimes ur right..
Old 12-17-2005, 07:19 AM
ok from my searching i found a few people say that the 88-89 pressure plate wont bolt up to a 90-91 flywheel
ok heres the deal with upgrading to a 90-91
89 - you just need to upgrade to a 90-91 clutch and flywheel. or you can just order everything for a 89
88 - if you want to upgrade to a bigger clutch get a 90-91 flywheel and pressure plate and buy a 84-87 prelude disc which is 21 spline and 212mm. or you can just order everything for a 88.
i would recommend going to a 90-91 because then you can order a lighten flywheel which is the shit.
Team Lonely Drivers
Old 12-17-2005, 07:24 AM
original poster, all you gotta do is count the splines, if its 21 then its a 88. if its 20 then its 89-91. if its 20 spline then measure it, should measure either 200mm or 212mm then from there you can figure it out on which clutch it is and which one you can upgrade too if you want
Team Lonely Drivers
