89 century runs rich after warmed up(no response on century forum)
hello,i know this is the lesabre forum but i couldnt get a response after several days on the century forum, any help would be apreciated. i own a 1989 century with the 3.3 liter, heres the problem. the car started running eratic , so i brought it in they replaced the computer, it ran great for about 2 months then after warming up one morning started stumbling and acting as if were running rich, engine light came up, and codes were o2 sensor and m.a.f, so i replaced both, while i was at it i replaced the fuel preasure regulator and tps, all new parts. i still get the maf code, even after swapping it out once again with another new part. runs great until warm, then stumbles and smells of fuel. plugs are black as well. anyone? thanks in advance.
Re: 89 century runs rich after warmed up(no response on century forum)
You could have a bad cam sensor. They control the injector pulse timing. It could also be a bad CTS (Coolant temp sensor.) It has to sense the engine temp to control fuel delivery during cold start and warm operating conditions.
Knowledge can be communicated, but not wisdom! ![]() ![]() |
ty i'l check that as well. today i started the car, again it ran fine until warm then started running terrible, there is black smoke, and gas dripping from the tail pipe. running rich obviously, but cant figure out why.
Re: Re: 89 century runs rich after warmed up(no response on century forum)
hello stuzman, no i do not have a scanner, just checking codes the ole fashion way reading the flashes. the only code that comes up is "34" . the engine light comes on about 5 seconds after i strt the car, runs geat until it reaches normal operating temperature then acts as if it is getting the wrong mixture. is it possible i have a bad maf sensor wire or connection? |
Re: Re: Re: 89 century runs rich after warmed up(no response on century forum)
I see that you've changed the PCM and TPS, so hopefully those items are okay. Good luck with your repairs and keep us posted of your findings! |
