Old 12-15-2005, 08:09 PM
newbicivic89 newbicivic89 is offline
Valve Cover Cleaner
What is the best thing to use to clean that blak paint off the to of the valve cover. Or can i just bake it then clean it off.
Old 12-15-2005, 10:17 PM
superbluecivicsi superbluecivicsi is offline
AF - Advisor
Re: Valve Cover Cleaner
just cleaning the valve cover?............simple green and some water.
99 [email protected] psi si- I voted for the Terminator for Gov.
95 HB- B16a2- SC34@12psi
WTB: USDM B16a2 or B16a3 complete short block. pm is the key.
FS: B series InlinePro cast mani, PnH RC 550s, and Hondata S2b. pm me.
Old 12-16-2005, 07:22 AM
johnb16a2's Avatar
johnb16a2 johnb16a2 is offline
Do you mean remove the paint? You could us a sandblaster or paint remover. The chemical can be found at most autoparts stores. GL
Old 12-17-2005, 08:30 PM
Tony's Avatar
Tony Tony is offline
TLD Member #1
Send a message via AIM to Tony
"Aircraft Remover"
Scuff up the paint pretty good. Spread some of that on it without touching it, and leave it on there for awhile. Rinse off. And you could probably sand the rest of it off. You can pick up AirCraft Remover at your local auto store. Get some thick rubber gloves, or a bunch of disposable latex gloves because it will eat through them. I used it in school and wore 3 pairs of latex gloves and it ate through all 3 pairs. If you happen to touch it, rinse it off with soap and water ASAP. You will understand why.
Tony
91 Civic Sedan DX - Stock 287k Miles
Old 12-17-2005, 08:47 PM
CivicSpoon's Avatar
CivicSpoon CivicSpoon is offline
There is no Spoon
stuff works wonders, and easiest way.
Old 12-17-2005, 11:03 PM
Tony's Avatar
TLD Member #1
Just realized what I said could be a little confusing about spreading it. Just get a plastic or metal spread to spread it out, don't let it touch your skin.
Tony
Old 12-18-2005, 02:52 AM
livinincalifornia livinincalifornia is offline
Send a message via AIM to livinincalifornia
yes don't let it touch your skin...owwww!
Old 12-18-2005, 04:41 PM
honda_luvr_2000 honda_luvr_2000 is offline
yeah that stuff works wonders on powdercoatings, so it'll get any paint off. i used it myself, and yeah keep it off the skin unless u like chemical burns. might take two uses, but if u follow the instructions on the can, u'll be golden.
Originally Posted by Greenblurr93
ahh i see said the blind man to his deaf wife, as he pissed into the wind, its all coming back to me now.
Old 12-18-2005, 05:29 PM
Tony's Avatar
TLD Member #1
Yea, sometimes you might have to use it a couple time, but if you get enough scratches on the paint and leave it alone for long enough, it should get it the first time. For some reason that stuff looses its effectiveness the more it gets moved around, so just spread it out and leave it for awhile. When I striped a die-cast car I was working on, I just filled a bucket with the stuff, dropped the car in it and left it for about 30 mins, went back and rinsed it off and got all the paint off.
Tony
