97 geo
i have voltage at the throttle body injector. car still won't start. is there a way to check injector to see if it is good or bad? thanks Mike
Re: 97 geo
quick and dirty way is to pull the air cleaner and watch for fuel to spray/ drip on the butterfly. If there is fuel but it doesn't start I would check for spark and compression. If those check out and you still think it is a fuel problem, pour a small amount of fuel down the TB and crank it with the throttle wide open. If it's a fuel problem it should at least try to start while doing that.
Re: 97 geo
Check to make sure your distributor rotor is turning. If it is not then your timming belt is broken and it wot't start till that is fixed.
