Go Back   Automotive Forums Car Chat > Volkswagen > Beetle - New/New Beetle Convertible
Old 12-15-2005, 03:39 PM
pondos pondos is offline
Angry 99 Beetle throttle problem
I have a 99 beetle has been sitting around for about 3 years. The battery was bad and replaced. Now when trying to start the throttle will auto adjust and it will die. The code was 1543 so replaced the throttle body and still having problem. If the throttle sensor is diconnected it will idle only. If you try and push on the gas it will die. Since the battery was dead do you have to do something secial for it to work right?
Old 12-17-2005, 11:39 AM
veedubmechanic's Avatar
veedubmechanic veedubmechanic is offline
VDUBMAN
Re: 99 Beetle throttle problem
you need a scantool to adapt the throttle to the ecm.
try slowly depressing the gas and hold when all the way down for 5 seconds then slowly release. that should reset the throttle..
ASE Master certified and VW certified. Just here to help
all check engine light codes ------>
http://www.automotiveforums.com/vbul...d.php?t=328630
Old 12-20-2005, 11:24 PM
ILoveBugsy ILoveBugsy is offline
Re: Re: 99 Beetle throttle problem
Hi, do you do that reset throttle thing with the motor off and the key switched to 'on' or with the car off or running or what?? Sounds like it might work, really wanna try it. Thanks
Old 12-21-2005, 08:51 AM
VDUBMAN
Re: Re: Re: 99 Beetle throttle problem
key on engine off
Old 12-21-2005, 09:53 AM
Re: Re: Re: Re: 99 Beetle throttle problem
can i use a pocket scan or do I need a factory scan tool?
Old 12-25-2005, 11:09 AM
Blackbeetle Blackbeetle is offline
Re: Re: Re: Re: Re: 99 Beetle throttle problem
If you want to reset the throttle control module(match to the ECM)
You need a factory scan tool.
Blackbeetle
Old 12-29-2005, 02:23 AM
cawwilliams cawwilliams is offline
the car has lost it's throttle adaptation due to the lack of voltage while sitting. the car will have to go to the dealer to reset the throttle system.
Old 12-29-2005, 09:37 AM
Throttle Body Reset with VAGCOM
1- Ignition ON but not started
2- Go into engine
3- basic settings, type in "60" and hit go or enter
4- Watch the right hand block count up til "ADP OK" (hopefully)
5- close the controler and your done.
check out this thread
http://forums.newbeetle.org/showthre...light=throttle
blackbeetle
