Old 12-15-2005, 12:38 PM
ViewtifulCivic ViewtifulCivic is offline
Send a message via AIM to ViewtifulCivic
Out of control idle
Hey guys. My car is steadily idling between 1500 and 2000. This is not cool. It's eating my gas mileage. Where I used to get 28-31 mpg, I now am getting 22-24. It's also a little annoying. My dad was the previous owner of the car and he said he had the same idle problem, and that was with the stock motor. Since I've done the swap, it has been idling high as well. Could it be one of the stock components that isn't changed during the motor swap, like the fuel pump or something? I've already messed with the idle screw on the throttle body and that didn't do much. If someone could, please point me in the right direction. Thanks.
1989 Honda Civic Standard HB
92-93 JDM B16A swap
92-93 JDM YS1 tranny swap
Stripped interior w/backseats removed
JDM EF9 SiR Taillights
Custom 2-1/4" exhaust w/ test pipe
Old 12-15-2005, 01:26 PM
civic_boy91's Avatar
civic_boy91 civic_boy91 is offline
Send a message via AIM to civic_boy91 Send a message via Yahoo to civic_boy91
Re: Out of control idle
check for a vacume leak on the intake manifold, maybe there is a hole in a line/hose (like break booster,fuel pressur reg. line,) get a squort bottel with water and spray 1 at a time to see it if stops...if it dose you found your problem...make sure all the ports on the manifole are blocked off (if for some reasion they are not used...) or pluged in good. also if your throttle cable is too tight it will cause it to rev up and down when it warms up.
_________________________________http://VelocityFactor.com________________________________
1990 si hatch
b20b si tranny
megan race header 2.5 custom exhaust
50 shot
integra da rear disk (w/ 4040 valve)
powerslot rotors and barded lines all around
1994 Dx hatch
stock
Old 12-15-2005, 02:09 PM
Re: Re: Out of control idle
If my throttle cable is too tight, how do I loosen it?
92-93 JDM B16A swap
Old 12-15-2005, 06:11 PM
YZ125rider21's Avatar
YZ125rider21 YZ125rider21 is offline
Send a message via AIM to YZ125rider21 Send a message via Yahoo to YZ125rider21
losen it on the intake manifold...if i had a picture it would explain it all....should be top center of the intake manifold on front....just back it off it its to tight but you dont want really any play in it either...but its a simple task to do though
90 Honda CRX Si
-Red/Black
-B20B/b16
-AEM CAI -/\- Apexi GT Header/2¼" Custom Dynomax Exhaust
-Tein SS CoilOvers with pillow ball monuts -/\- ST Swaybars/Energy Suspension Bushings
-16x7 Lightweight Rotas -/\- Pro Stop Rotors -/\- Goodridge S.S. Brake Lines
-Skunk2 Shifter -/\- MoMo Steering Wheel
Old 12-15-2005, 07:12 PM
superbluecivicsi superbluecivicsi is offline
AF - Advisor
other causes are:
map
tps
iacv
99 [email protected] psi si- I voted for the Terminator for Gov.
95 HB- B16a2- SC34@12psi
WTB: USDM B16a2 or B16a3 complete short block. pm is the key.
FS: B series InlinePro cast mani, PnH RC 550s, and Hondata S2b. pm me.
Old 12-15-2005, 07:20 PM
Jos4DCivic's Avatar
Jos4DCivic Jos4DCivic is offline
Send a message via AIM to Jos4DCivic
Yup, check those .Could aslo try cleaning out EACV with some TB cleaner.
GL
91 Hatch SI
Heart of my Baby - DOHC ZC - Si tranny - PG7
Finally painted!!!
Old 12-16-2005, 04:08 AM
welfarepc welfarepc is offline
i had the same problem with my old civic, try to unplug the power cables to the IACV (should be located on the driver side, and will have a green plastic connector piece). if the idle problem stops u know what the problem is. u should reset ur ECU after so u dont get check engine light.
when i unpluged mine, the problem stoped. i tried to clean it but it didnt help, then i sold the car. i wonder if u bought my old civic?? lol
Dan
Old 12-16-2005, 05:26 PM
Thanks guys, I'll look into all those things. My buddy said it could be because of my test pipe and exhaust pipe B. Could that be it? I don't think it is.
92-93 JDM B16A swap
Old 12-17-2005, 11:28 PM
i dont think so...i have stright pipe frome the header back and a cheap muffler (stright through..w/silencer) and my car idles fine
1990 si hatch
b20b si tranny
50 shot
1994 Dx hatch
stock
