Go Back   Automotive Forums Car Chat > GMC > Sierra
Old 12-15-2005, 10:21 AM
Estrangedlsc Estrangedlsc is offline
Send a message via AIM to Estrangedlsc
Angry Cam Position Sensor Malfunction
I'm new to the boards, but I hope someone can help me with this:
I've got my service engine soon light on... came on once, with the message "Cam Position Sensor Malfunction" but the truck was running fine, so I reset the light... truck ran all day, didn't come back on... the next morning I start it and 10 seconds later, it's back on.
It's been 11 degrees lately, and this is a childish question, but could that cause the sensor to malfunction? The truck is running fine, no hesitation, no odd noises. And I haven't done any work on it in a month or so. Just out of the blue started giving me this light.
I hope replacing the sensor is a cheap/easy job if that's what it comes too... anybody have any ideas?
edit: my name doens't show the model... 1998 gmc sierra 1500, 5.7 ltr
Old 12-15-2005, 10:42 AM
swensonb71 swensonb71 is offline
Send a message via Yahoo to swensonb71
Re: Cam Position Sensor Malfunction
the temp outside shouldn't make any difference. however, i have had the similar problem with mine when i replaced the intake manifold gasket and had the cam sensor timing off. i had talked to a friend of mine at the dealership and he said that if it gets about 2 - 4 degrees off of time the service engine light will come on. if it gets to 6 degrees or more it will stay flashing service engine. to cure it you just need to have the cam sensor timing reset at the dealership unless anyone else knows how to do this without going there?
Old 12-15-2005, 11:00 AM
Re: Re: Cam Position Sensor Malfunction
Any idea what would get the timing to change 2-4 degrees? Engine hasn't been touched in over a month so not sure why it would just start happening all of a sudden.
1998 GMC Sierra 1500 Shortbed, 5.7 ltr
1990 Lincoln Mark VII LSC
1988 Lincoln Mark VII LSC
1990 Jeep Wrangler
1991 Lincoln Town Car
1985 Mercury Grand Marquis 2-Door
All That = No More Yard Space
Old 12-15-2005, 11:11 AM
Re: Re: Re: Cam Position Sensor Malfunction
that I am not sure of as of yet. right now I am haveing the same similiar problem. it has been about a year now before it happened to me again. I am going to talk to my friend at the dealership again and I will let you know what I find out.
Old 12-15-2005, 11:24 AM
Re: Re: Re: Re: Cam Position Sensor Malfunction
Sounds good, I appreciate it! Thanks
1990 Jeep Wrangler
