Old 12-15-2005, 10:50 AM
drew_5_2 drew_5_2 is offline
Angry god help me, electrical problems
I have a 96 blazer. A fuse keeps blowing and when it does all of the gages go dead and the altinator stops charging the battery. I've replaced the fuse and it will work for a while but then it will blow again. I think it is a loose/pinched wire however I have no idea which wires to check.
Old 12-15-2005, 11:49 AM
Gabe25's Avatar
Gabe25 Gabe25 is offline
Re: god help me, electrical problems
Which fuse keeps blowing?
1994 1st.Gen. S10 Blazer Tahoe
Aloha
Gabe
My Fleet
Old 12-15-2005, 12:52 PM
Re: Re: god help me, electrical problems
number 4 fuse, 10 amp for the insturments
Old 12-15-2005, 12:58 PM
Cailen Cailen is offline
Do you have any aftermarket electronics in the vehicle? Ie stereo, stereo amp, subwoofers, inverter, underglow neon, etc?
Any commonality in when this fuse blows? Ie whenever you're listening to your 2pac cd with the volume max?
Most auto parts stores will test your alternator for you for free.. might be worth your while to have it done.
Originally Posted by blazee
If you would pull your f ing head out of your f ing ass and read the f ing thread, you will see that I posted the most common f ing cause in f ing post # 4 and Swalt followed it up with more f ing details in f ing post # 8. From what we f ing posted you should be able to f ing realize that if you have two new f ing tires on the f ing front and two raggedy ass f ing tires on the f ing back... that is probably causing your f ing bang. Try not to be such a tool. Can you do that, Thank you. f head!
Old 12-15-2005, 01:11 PM
no after market products
Old 12-15-2005, 01:13 PM
no after market products and at first we thought it was the altinator so we put a brand new one in
Old 12-16-2005, 05:53 PM
Southern Comfort's Avatar
Southern Comfort Southern Comfort is offline
I have a shematic for a 1999, if it will help you, I can e-mail it to you. It's 3.25 Meg and takes me about 20-25 minutes to e-mail it. Just let me know if you want it.
Southern Comfort
Old 12-18-2005, 04:25 PM
Shawn Herrity Shawn Herrity is offline
Same thing happening to me! I found a shortcut!
The same exact thing is happening to my '93 Blazer. You will also notice that when the fuse blows, your transimission will go into fail safe mode also. It gets stuck in 2nd gear and the only way to start with any power is to manually downshift on the column and then shift back upto drive when you have enough RPMs. If you pull your fuse box out, you will notice that two wires go into the back of the fuse that keeps blowing. You can seperate these two wires. One goes to your gauges and your altinator. The other controls the shifting of your truck. If you only hook the wire back-up that goes to the gauges & altinator you can at least drive your truck without the battery going dead. I've been driving like this for a while. You'll need to start out in 1st and then upshift to (D) once you have enough speed. I traced these wires back to the computer.... I thought. I went and bought a new computer today, installed it, and the same fuse keeps blowing.
Let me know what you find out, I would love to fix mine as well!
Thanks, Good Luck!
Shawn
Old 12-23-2005, 07:27 PM
y2kblazer y2kblazer is offline
unless I'm missing something, if the fuse has 2 wires on the "out" side & you hook the dash wire up & they work, then wouldn't it mean the tranny is causin' the problem?
Old 12-25-2005, 08:44 PM
The wires are the ones that go into your fuse box on the Drivers side floor. I'm not sure what is causing the fuse to blow. All I know is that it tells the Transmision to go into safe mode. It could be a number of things. Maybe a wire grounding out, maybe it is something on the transmission. I really don't think it's something with the actual transmission, because before the fuse blows the truck will drive for maybe five miles, perfectly. The transmission shifts great.... Until the fuse blows.
I'll be working on it tomorrow. Hopefully I'll figure it out!
Old 12-25-2005, 11:04 PM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Crap fuse 4 feeds half of the car.
The rear window defoger switch may be a prime suspect.
See if this pfd helps.
http://members.troublecodes.net/crunch/Fuse4.pdf
Good luck MT
MT
Old 12-26-2005, 10:02 AM
LS19962DRBLAZER4X4 LS19962DRBLAZER4X4 is offline
Exclamation Re: Another important thing about fuses:
When you buy, finance or lease your GM Chevy Blazer the fuse box contains
replacements, make sure you take the replacements out before you go to
the dealership or garage. I found more theft in garages,mechanics who just take your belongings. Also check out OnStar.. equipment and DVD /CD Disk players they have a habit of blowing fuses.
Old 12-26-2005, 10:23 AM
GMMerlin's Avatar
GMMerlin GMMerlin is offline
I know stuff
Re: Re: Another important thing about fuses:
Thats a pretty broad and bold statement...so are you impling that I am a theft because I work on vehicles..
No wait..you said mechanics...good thing, because a professional auto Technician doesn't disturb a customers belongings.
You need to look only at the items that are powered by that fuse.
A blown fuse indicates that there is a high current draw on that circuit. Possible causes could be a short to ground or a componant that is drawing a high current.
Why do you never have enough time or money to do the job right the first time, but enough time and money to do it again?
Got all the certifications
25 years ASE Certified Master Technician
GM WCT
Yea..I work at a DEALERSHIP....got a problem with that?
Want to diagnose cars like the Pros? FOR SALE: OTC Perception 2 channel Labscope (badged as a Matco Reality)
This is my personal labscope that I use to diagnose waveforms, like new, comes with leads and training video
PM Me for details
Old 12-26-2005, 11:01 AM
MT-2500's Avatar
AF - Advisor
Good grief
Why would us mechanics/techs who give our time away to help people here and turn around and steal a spare fuse?
But it is like my mama always told me a skunk always smells his tail end first.
So if the shoe fits you can wear it.
MY
MT
Old 12-26-2005, 05:25 PM
Re: Re: Re: Another important thing about fuses:
Thanks for the post. I downloaded the pdf. It's freezing rain here now, so I will detatch the rear-defogger in the morning and then replace the fuse. I guess if I can make it to work without the fuse blowing, that was it. The rear-defogger stopped working last winter anyway. As a matter of fact the rear-wiper stopped working this summer as well... maybe it's all connected, I hope so.
Thanks Again!
Shawn
