Go Back   Automotive Forums Car Chat > Ford > Ranger | Courier
Old 12-15-2005, 09:01 AM
ladderman643 ladderman643 is offline
Smile 1999 Ford Ranger 4wd-clunk Noise In Drive Train
When U Stop And Take Off It Makes A Clunk Noise-its Like Rear End Rolled Up Then Releases When U Take Off-
I Have Done The Psb From Ford Dealer Where They Change Driveshaft From Steel Style To Alum Style-it Worked For Year-they Said To Grease It But There Is No Grease Inserts On Drive Shaft-any Good Ideas Out There?-thanks
Old 12-15-2005, 09:57 PM
maestrojv maestrojv is offline
Re: 1999 Ford Ranger 4wd-clunk Noise In Drive Train
Hmmm.... Sounds like U joints to me. Check your U joints on all ends of the rear and front shaft assemblies for excesive play, wear, damage, etc. Bet if you replace these your problem will disappear. been there.
Old 12-16-2005, 07:45 PM
Escorts4ever Escorts4ever is offline
Did you get the 4wd working from your last post??? When they say grease the shaft they mean to take the slip yoke apart and grease the splines. Put a mark on both parts so that they go back together in the same place or you may get a vibration.
Old 12-19-2005, 08:56 AM
Re: Re: 1999 Ford Ranger 4wd-clunk Noise In Drive Train
ACTUALLY I DID NOT GET TIME THIS WEEKEND.I HAVE TROUBLE SHOOTING AS FAR AS WHAT U RECOMMENDED.AND EVERY THING SEEMS
TO BE WORKING.THE WHEELS TURN FREE AND THE SHAFT IS ENGAGED.WHEN I PUT BACK INTO 2WD ON SWITCH THE SHAFT IS FREE.
I HAVE CHECKED THE FUSES IN FUSE BOX UNDER HOOD-OK!.I HAVE FOLLOWED VACUM LINES TO SWITCH SOLENOID ,AND WONDER IF THIS MIGHT BE THE PROLEM????.IT HAS WIRING AND VACUM TO IT.UNLESS U HAVE ANY OTHER IDEAS?
WHAT U RESPONDED ON THE GREASING THE YOKE IS WHAT I KINDA THOUGHT I WAS GOING TO HAVE TO DO.THANK-YOU
