Old 12-15-2005, 04:36 AM
tune1552 tune1552 is offline
knocking in steering wheel.......
I have a 04 Z71, Im getting this knocking feeling and sound in the steering wheel as I drive. I only have 22k miles, its a feeling like there is slack or something in the steering or something. Does anybody else have this or know what it is? Thanks.
Mike
Old 12-15-2005, 07:30 AM
jeverett's Avatar
jeverett jeverett is offline
Send a message via ICQ to jeverett Send a message via AIM to jeverett Send a message via MSN to jeverett Send a message via Yahoo to jeverett
Re: knocking in steering wheel.......
I think theres a thread on here that covers this already. Not many replies, but answers your question I do think.
http://www.automotiveforums.com/vbul...clunk+steering
1998 ECSB Z71
Whelen LED's
Kenwood 2-way
"BIG 3"
2500+ watt audio
Old 12-17-2005, 01:31 PM
masapell's Avatar
masapell masapell is offline
Mike
Yeah, mine does that too. I think they put that in as a factory add on!
2014 Ram 1500 Crew Cab
Old 12-17-2005, 02:52 PM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Head it on down to your local dealer.
He should take care of it for you.
Have him run the vin no for recalls and tsb's.
Some of them had a steering shaft problem.
MT
MT
Old 12-17-2005, 09:40 PM
JS632 JS632 is offline
Send a message via AIM to JS632
Yes....I have an 03 sierra z71....was doin tha same thing... i took it to the dealer and he told me that it was a recall but gm hadn't sent any recall notices out...i think i only had 15,000 miles when this happened. The problem was what he called the intermediate steering shaft... He said he had many of these going bad on the 03's. It is the shaft between the shaft that comes from the steering wheel and the steering box. It causes a bumping or popping noise and feeling in the steering wheel while going around a curve or turn. They replaced mine nearly 30,000 miles ago and havn't had any trouble since. I assumed they fixed this in the 04's but my dad purchased a new sierra 2wd in 05 and it had the same problem after only 10,000 miles. So go to your dealer and they should fix it for you. Hope this helps you.
Old 12-18-2005, 04:26 PM
masapell's Avatar
Re: Re: knocking in steering wheel.......
MT
Do you think that this would still cover a 2000 Silverado? I probably wouldn't be in luck, but I thought I might try.
Matt
Old 12-18-2005, 05:24 PM
MT-2500's Avatar
AF - Advisor
Masapell
I am not sure how many years it covers but by all means.
Give it your best shot. You may get luckie.
Good luck MT
MT
Old 12-18-2005, 05:28 PM
Crasen Crasen is offline
Re: Re: Re: knocking in steering wheel.......
Call the dealer and give them the VIN, if it is a recall he should tell you and fix it for you
Old 12-19-2005, 09:50 AM
twomorestrokes's Avatar
twomorestrokes twomorestrokes is offline
Unless something has changed, this is a bulletin, not a recall. Warranty ends on this when your vehicle coverage ends. GM has had this issue across the board for many years. My friend at the dealer takes the intermediate shaft out and repacks it periodically. Last I knew, replacing the shaft is as temporary as repacking, as the design has not changed. My HD does it, my friends 1500 does it, they ALL do it. Our Bonneville had the shaft replaced, then had to be repacked twice after that in the 2 years that we had it. Olds Intrigues are really bad.
This is what bothers me most about GM. They have a giant issue on all of their models like this, and they keep the same design for many years to come, knowing that owners are having to pay for repeated repairs. Everytime I start a customer's GM truck cold and hear an exhaust tick, I know that the left rear exhaust manufold bolt has broken off in the head. I see it all the time. My '95 did it on the 5.7 and now my 6.0 has done it in the same location. Hmmmm. Bulletins on both vehicles for the same thing as well as the 4.8 and 5.3. Once again, you'd think they'd fix the problem instead of re-applying the bulletin for the next model...
Old 12-19-2005, 11:58 AM
masapell's Avatar
I often wonder the same thing. You would think that it would be more beneficial to company image to get things right as soon as possible. With these trucks costing so much, and the Japanese gaining ground in the full size market, it is something GM should really work on.
Matt
Old 12-19-2005, 12:28 PM
kmschna kmschna is offline
Red face Re: Re: Re: knocking in steering wheel.......
Matt
Easy fix on that 2000 Silverado! Pick up a intermediate steering shaft lube kit P/n?????????,...they know. It cost about 13-17 bucks. Follow the directions. Basically all your doing is pull part of the shaft, two connections, one in the engine compart, one under the steering wheel. Press the lube in and reassemble. Done. I did it after 3 years of clunk on my 2000 and low and behold,...fixed. One of my most satisfying repairs. Good luck. I may have to do it again someday, so I saved the kit.
Old 12-19-2005, 01:04 PM
Re: Re: Re: Re: knocking in steering wheel.......
Exactly correct!
My friend completes the repair in no time. Takes him three times as long to complain about how his bad back can't get under the dashboard anymore and how the warranty pay is crap than it does to actually do the repair.
Old 12-19-2005, 02:20 PM
masapell's Avatar
Perfect. Thanks for the info!
Old 12-19-2005, 02:33 PM
BlenderWizard's Avatar
BlenderWizard BlenderWizard is offline
Send a message via AIM to BlenderWizard
How hard is it to get to the part under the steering wheel?
"When I step on the gas, I want people to think the world is coming to an end!" - Homer Simpson
2002 ECSB, Nelson Tune, LS1 electric fans, 145A alternator, K&N FIPK, 160º T-stat, TB coolant bypass, Corvette servo, 4 headlight mod, blue LED gauge cluster
Old 12-20-2005, 12:08 PM
Wink Re: Re: knocking in steering wheel.......
Depends on how much beer you've drank
