Old 12-15-2005, 01:00 AM
cody_stl cody_stl is offline
Send a message via ICQ to cody_stl Send a message via Yahoo to cody_stl
'95 Z28 Drag Build HELP!!!
Hi All!
Aquiring a '95 Z28 soon and i am goin to park her in the garage and let her sit while i build her piece by piece.But i am new to the high HP V8 world and need help badly.
First of all,something i cant find,all i find is numbers and letters that i dont know what they mean...is what transmissions are used for 500-600hp and torque drag cars?they dont seem like manuals when you watch races cause their seems to be no clutch action happening....just wondering...and where online can i look up and research these trannies?Another thing out of Summit Racings Bare 350ci blocks is a good one to start with,i plan on pitching the 200k engine thats in it and building a fresh monster?I think the aluminium blocks are KINDA expensive.I know 4bolt mains are a must,and siamese cyclinder setups are good,anything else i should know?what exactly is siamese cylinder config?thicker cylinder walls right?
So everyone knows and can better help me...i THINK my strip goals are gonna be something like 11-10 second 1/4 miles,with room for improvement when i get adjusted to the High HP.Would the engine be better suited for drag as a Carb or Injected engine?Which would you prefer?I dont want it SOOOO tilted towards drag that i cant rumble her around town once in a while.what kinda HP&Tq would i need to be puttin up a 10.5 sec 1/4mile?How does one go about using a stroker crankshaft?does the block or cylinder head need to be special?what are the advantages of a stroker setup and should i use this approach?What kind of suspension and motor mounts should i look into?I have never been involved with puttin this much HP to the ground so i need some BIG info on the suspension.What are some basic DO's and DONT's of building a strip car?i have blabbered on my newbie questions long enough...i just really wanna get into some big numbers,i am so sick of my honda and working hard just to get under 200hp....very un rewarding.I am an apprentice at a Auto Shop,but ust started so i am still getting my feet wet,but cars are what i LOVE,and i hope the nice people here can help me get my feet wetter in the drag car sense.The biggest thing i cant understand is what tranny's and torque converters and trans brakes and rear ends to use and what they do?!And what kinda Compression ratios V8 are safe to use with Nitrous....MAYBE a supercharger as well.I know with my honda if i wanted to boost it i would have to drop my CR to like 9.0:1 to be SAFE.When it comes to rippin out the old engine and installing my newly built motor,what stock components should i retain?such as ignition,timing,ecu's,fuel pump...should i pretty much strip the car bare of everything?Would i be able to BASICALLy bolt in this aftermarket beast...what about all the externals(alternator,P/S pump*maybe*),will all this stuff mount to the aftermarket block as it does the OEM block?Any info on Poducts ya'll gimme would be REALLY helpful if ya had online links to buy or look at em...thanks alot
P.S.-what about roll cages....how do they install them...do ya just strip the interior and weld them to the chassis or what?and how can you intercool a roots type super charger...and can a roots type SC be used with fuel injection?
Old 12-15-2005, 01:01 PM
another question....i'm looking through these crate engines and MOST of them are externally balanced,and some of the expensive ones are internally balanced...which should i get?if i bought a bare block and bought the crank,rods,pistons,seperate what would it take to balance them?
Hope to get some replies soon
thanks
Old 12-15-2005, 10:10 PM
88camaroproject's Avatar
88camaroproject 88camaroproject is offline
Send a message via AIM to 88camaroproject
Re: '95 Z28 Drag Build HELP!!!
if you have 10,500 dollars to spend you can buy a 1000 hp motor all assembled and ready to go... and umm roll cage, i am thinking of getting a roll cage too jsut to stiffen chassis and hook my harnesses up to, but as far as i know you just pull the carpet back bolt or weld the roll bars in there appropriate mountsing places and cut carpet to fit around the bar. and you will ned subframe connecters and upgrade your rear control arms, get a nice posi rearend with like 3.42 gears or up. bigger disc brakes, strut tower brace, some pretty wide rims in the back with drag radials, driveshaft safety loop, aluminum driveshaft, and automatic trans, like maybe a built up 700r4 or a built th350 or th400 with a shift kit and like 3400 stall converter or something (dont know much about stall converters), and stiff loweringspring and some nice shocks and struts, pace performance sells lots of nice engines. depends on how much your lookin to spend, cause its gonna take a lot of $$$$$$. i think like almost any 350 block will have most of the same mounting points and stuff. if you got 5000 bucs heres a 350 that makes 400 hp outta the box.
well good luck
87 firebird formula ws6
(currently has a old 78 305 with the following upgrades,
including lots of miles and stock heads and internals....oops)
crane cam cam specs
performance valve springs and retainers, flowtech headers, 255 lph fuel pump,
holley 600cfm carb, weiand single plane manifold, a healty diet.
14.90 1/4 mile....just wait for the 406 to be finished
MY VIDEOS
MY PICTURES
-Tom
Old 12-15-2005, 10:11 PM
oh yeah, heres the link, http://www.paceperformance.com/index...D&ProdID=73192
crane cam cam specs
MY VIDEOS
MY PICTURES
-Tom
Old 12-15-2005, 10:25 PM
cuda_dude cuda_dude is offline
Will Whore For Car Parts
Send a message via AIM to cuda_dude
1st question... why throw out the lt1 block?? why not rebuild it to what you want... lt1 blocks are great for making power and great for handling it...
1995 Camaro - Z28 - M6 - Hardtop
2007 GMC Sierra 2500HD SLT Classic
-R.I.P. Andy (Hypsi)-
Old 12-15-2005, 10:30 PM
lol, i didnt notice he was talkign about a 4th gen, well yeah, keep the lt1 and pull it get it put in a hot tank or whatever to completely clean it out, get it bored and get some nice heads and huge cam and msd ignition, new crank, port out intake manifold, plenum, and get a bigger throttlebody, bigger fuel injectors, higher flow fuelpump, fuel pressure regulator, roller rockers, headers, cold air induction, 3 inch exhaust, ummm forged internals and some NOS??? or turbo it or something.
crane cam cam specs
MY VIDEOS
MY PICTURES
-Tom
Old 12-16-2005, 09:04 PM
Re: Re: '95 Z28 Drag Build HELP!!!
I just figured with the high miles it would be better to buy a new block nd heads and start from scratch.I was lookin at some Dart 350 blocks and they arent toooo expensive for a cast iron type....but if ya'll say the engine in it will work fine,i could give it a shot...how much can you bore an lt1 block out?How much power wiyth the listed stuff above could i be lookin at once it is finished?would doing all this require me taking it to a Pro Tuner to have it tuned right,or could i beef up the internals and all that without having it tuned?
One thing i really want is a way to learn the ins and outs of this magnitude of Drag racing....short of apprenticing under a racer ya know....theres gotta be a way to learn all the basics of building this kinda car.
thanks for the replies guys...keep em comin
I have found some other camaros for sale a little cheaper....if i was willing to buy a new block...could i then possibly buy a v6 automatic and still throw a 350 and new tranny in it....with the all out mods i plan on doing i could pretty much start with any model couldnt i?
Old 12-16-2005, 09:31 PM
Genopsyde's Avatar
Genopsyde Genopsyde is offline
The President
Send a message via AIM to Genopsyde Send a message via Yahoo to Genopsyde
honestly, I would never tear up a z28 to make it a race only vehicle. I'd go with the 6er and do the engine swap and beef up the suspension and chasis.
Old 12-16-2005, 09:52 PM
666_speed's Avatar
666_speed 666_speed is offline
Son of Satan
with making it a drag car too...i agree i would also start with a v6...they are usually cheaper and with everything that you are changing it wouldnt be much different than doing that to a v8...definately would need a better chassis and suspension like stated but im assuming since its going to be a race car anyways you know that...
Old 12-16-2005, 10:51 PM
yeah its gonna be primarily track so i GUEss i could buy a v6 model....then i would HAVE to buy a new engine...might buy a z28 anyway and keep my options open.I just looked up some tranny's on racetranmissions.com and they have a th400 tranny that will handle up to 950hp....but is a th400 really a 3 speed tranny?is this a good tranny for drag racing?i thought at least a four speed would be ideal...but then again what do i know.i figure a four speed would be better for the street driving time.if anyone knows any sites with a GM 4 speed tranny that can handle 700hp lemme know the link so i can check em out.
thanks again guys...
keep em coming
Old 12-17-2005, 01:12 AM
1986Z28's Avatar
1986Z28 1986Z28 is offline
Has a Camaro
Send a message via MSN to 1986Z28
a dart little m cast iron block would be good for this, roll bar is not just welded to floor, a plate is welded to the cage and has bolts going through itand the floor and a plate on the other side(bottom) of the floor pan, or you can tie it straight to the frame, for a 10-11 second qt. a 8 pt cage would be enough, in the topic of carb or fi i would go carb, to get you car into the 10's you dont need nitrous or forced induction, i just built a 396 bbc which im drooping into a 3rd gen camaro thats becoming a drag car and im running a 750 holley double pumper, with a roots type superchrager or a blower, you dont run an intercooler, it is driven off the crank not exhaust gas like a turbo so it does not produce as much heat as a turbo would, for all you other cage and safety needs try and find an NHRA tech guy, one that can tell you what would be safe and what wouldnt be. for do's and dont's, DONT BE CHEAP, dont buy crap, you get what you pay for, dont take shortcuts in building stuff, its you ass on the line is you ever get in a accident with the car, so do things right, i see so many people building stuff like cages wrong all the time, hope i was of some help
Formerly Blownalcoholboy
1986 Z28, 400ci SBC, Twin borg warner billet S467 turbos, Reid case powerglide, Moser 9". Holley EFI, Boost Leash. 950RWHP on pump gas, 1200rwhp on race gas (22 psi)
Best ET 1/4: 8.35 @ 170mph (275 drag radial)
Best ET 1/8: 5.44 @ 132mph (275 drag radial)
Best 60': 1.31 on the back tires (275 drag radial)
AF User Rules/Guidelines
http://www.automotiveforums.com/vbul...uidelines.html
Old 12-17-2005, 01:18 AM
1986Z28's Avatar
Has a Camaro
for a trans with a small block for a pure drag car i would go with something like a powerglide with a trans brake, if you want to hit 10's or faster, btw between the th400 and the th350 go with a turbo 350, turbo 400 can handle alot more, but a built 350 is alot lighter, i wouldnt go manual in a drag car, they spit out to many parts, if your just getting into dragracing, i wouldnt start with such a big project, start with something small, a weekend bracket car or something, before you spend a crapload of money get to know the sport
Old 12-17-2005, 12:23 PM
92zcamaroperson's Avatar
92zcamaroperson 92zcamaroperson is offline
wise words from alcoholboy. You need to get your basic knowledge together first. Go to the book store and start reading up. I made a post a while back about a book that i got. The publisher is HP books and its written by John lingenfelter and is called building a performance small block or something like that. Very good book. It doesnt matter whether you get a regular camaro or a z28 everything has to be replaced anyways. I would begin with the suspension and drivetrain and then the engine so that you can research what engine you really want. Also if you get a new rear end and a strong transmission with a trans brake in it youll get great quarter times even with a stock motor because you can get such a huge launch. A LT1 block with forged internals will handle the 500 or 600 horses that your looking for. Stock heads will take you to about 500 n/a. A 383 lt1 combo with some AFR aluminum heads would be one thumpin motor and a pretty easy build. Then stick a procharger on it if you want more. A 12 bolt rear is a sure thing or you can build up a stock 10 bolt and take a chance. The 10 bolt is cheaper but you will risk breaking it if you put slicks on the car and might handle a 11 sec car.
92 z28 camaro 5.7 TPI
current - slp intake runners and base-BBK 52mm throttle body-MSD 8.5mm wires, blaster coil, and 6AL Box-edelbrock headers-160 degree stat.-hotchkis strut tower brace
waiting in the garage - LQ4, milled heads 317 casting (10.5 to 1), hardened pushrods, ported LS6 oil pump, manley dual spings with titanium retainers, MTI X1 cam, hawks longtube headers
Old 12-17-2005, 03:20 PM
An LT1 with stock internals can safely handle 500+hp.... the stock internals are forged..
Old 12-17-2005, 03:22 PM
Savage Messiah's Avatar
Savage Messiah Savage Messiah is offline
Send a message via AIM to Savage Messiah Send a message via Yahoo to Savage Messiah
are they really?
97 Camaro - 2.077 60', 14.745 @ 92.20 - still down, one year later.
194k miles-160* thermo-V8 shocks/springs (V6 rear springs)-3" Magnaflow !cat (3" dynomax bullet) back-SLP CAI-stock boxed LCAs-poly tranny mount and torque arm bushing-custom HPTuners tuning-4.10s/eaton/TA girdle-3.5" alum DS-spohn LCA brackets-prostar skinnies
179.75 RWHP, 204.52 RWTQ
ON ITS WAY: MORE
R.I.P. Andy
87 Benz 190e - DD
01 EX250 - still gotta get my license for this thing
