Old 12-15-2005, 12:20 AM
wildmanmcghee wildmanmcghee is offline
1998 Blazer wont start
ok.. i get in my blazer... stick the key in the ignition... turn the key... nothing.. well.. there is a click.. my battery meter says my battery is fine... it has done this before but usually will start after a while... one time me and my friend pushed it a little bit then tried it again and it worked... i was wondering if anyone had any ideas for me on what to do...
Old 12-15-2005, 02:28 AM
Gabe25's Avatar
Gabe25 Gabe25 is offline
Re: 1998 Blazer wont start
Even though the battery meter reads 12 volts. Your battery under load mite not be putting out enough to start your motor. Check your battery connections at the battery and starter. Make sure that you have good ground. Let us know what you come up with.
1994 1st.Gen. S10 Blazer Tahoe
Aloha
Gabe
My Fleet
Old 12-15-2005, 06:57 AM
essten essten is offline
Send a message via AIM to essten
is it the silinoid on the starter? if you crank it on off on off on off really fast does it start?
Old 12-15-2005, 07:32 AM
rlith's Avatar
rlith rlith is offline
Send a message via AIM to rlith Send a message via MSN to rlith
As said above, check and clean your battery connections. Have you tried jumping it? If neither one works it's more than likely your starter.
