Go Back   Automotive Forums Car Chat > Chevrolet > Avalanche | C&K | Silverado | Suburban | Tahoe > Suburban
Old 12-15-2005, 12:14 AM
bramwell bramwell is offline
suburban misfire
have a 99 suburban 5.7 with a constant misfire on cyl 1 and 8, random on 4 and 5 check electronics steady spark. did a injector balance test, 7-9 psi drop on all injectors except 1 and 5 they dropped 20 -25 psi.
tried the motovac injector cleaning but no change. the misfire will change periodically even when just sitting and idling. under load and acceleration it sems to smooth out but my guess is the misfires are masked by the other cylinders. the scan tool shows the miss fires on 1 and 8 with intermitten on 4 and 5. I think replacing the injectors is in order. appreciate any comments
Old 12-16-2005, 02:44 PM
Loekee75's Avatar
Loekee75 Loekee75 is offline
Send a message via Yahoo to Loekee75
Re: suburban misfire
what about your plugs/ wires?
http://www.cardomain.com/ride/2653398
1992 Buick Park Avenue (Daily driver)
2001 Saturn SL1 (gas saver)
Old 12-16-2005, 04:46 PM
Re: Re: suburban misfire
checked plugs, moved no 1 into no 3 cylinder etc, no 1 still a constant misfire. thinking I may have multiple separate problems here
Old 12-16-2005, 04:57 PM
zirb zirb is offline
My 99 did the same thing. Then one day it wouldn't start. It was the coil wire. Just an idea.
Old 12-17-2005, 08:46 AM
thanks will check it out
Old 01-27-2006, 03:40 PM
Lu-san Lu-san is offline
Send a message via Yahoo to Lu-san
I have a similar problem on my 96 Sub 5.7 L eng. I get random missfire codes (P300 I think). I have an AutoXray 600 code reader so I can check the missfires on each cylinder. Most misfires on cyl 4, 5, & 6 with vry few on the others. I've changed plugs, plug wires, dist cap, rotor, cam sensor, & coil. Still get the missfires. I haven't had much time to work on it lately (still drivable but the check enginle light is always on). One thing I have NOT checked out yet is that I get a stored code of (P1100). Something about a manufacturer specific transmission code. I'm thinking it may have something to do with the TCC solenoid but when I get a-round-tuit I'll check it out.
You may want to have somebody with a realy, really good code reader (like a dealer or transmission shop) read the codes for you.
Old 01-27-2006, 05:24 PM
Jeremy-WI Jeremy-WI is offline
Lu-san
There is no GM code P1100, it is a problem with the Auto Xray software. I had a phantom P0700 and P1100 when I hooked my first auto xray to my 96 K1500, checked my factory service manual and no mention of a 700 or an 1100 code. Transmission codes are going to be P07?? or P17?? because of the OBD standard. The updated auto xray software should fix the code
Old 01-06-2008, 09:12 PM
tgperk tgperk is offline
I have a 99 suburban with a very similar problem. Did you find a solution ?
Old 01-11-2008, 01:00 PM
WikedKlown WikedKlown is offline
Same Here... Any Solutions?
Old 01-11-2008, 03:12 PM
16th hippy 16th hippy is offline
this thread was started over 2 years ago. would be a good idea to start your own threads and link to this one if needed. mods will likely close this thread down soon and no further posting will be allowed to it. if you are still having this problem, start new thread, include year make and model, engine size and any info on parts changed and so on.
Disclaimer: I am not perfect, i may be wrong in my advice from time to time. Also note that any advice given is as is with no warranty whatsoever, and i have zero liability if you get hurt for not being safe while working on your vehicle.
