Go Back   Automotive Forums Car Chat > Engineering/ Technical > Tires and Wheels
Old 06-05-2002, 09:55 PM
98EclipseGS 98EclipseGS is offline
18" rims
i'm looking to put 18" rims on my eclipse. its a 98 Eclipse GS. What all will i need to do to make them fit?? will i need new chamber's, etc. what all would i need????
Old 06-07-2002, 11:45 AM
w8n4myevo w8n4myevo is offline
Send a message via AIM to w8n4myevo
I almost decided to do the same thing, you will need a set of springs and shocks so that the body cant travel as far down and dont run anything over a 40 series tire. Do this the right way and you shouldn't have a problem
"Its not the size of the dog in the fight, its the size of the fight in the dog"
Old 06-11-2002, 02:18 PM
well im getting a set of Eibach Pro-Kit lowering springs (1.3" drop in the front and back). but what brand should i get for the other things i need? and if ya can put a web address next to it if ya can. Thanks for your help.
Old 06-28-2002, 07:35 PM
Got some new info for you,
the Rs comes stock with 14" and a 70 series tire
A 17" rim with a 40 series tire is the exact same tire
A 18" rim with a 35 series tire is the exact same as both listed above
A 19" rim with a 30 series tire is the exact same as all listed above
Do you see the way this works? Every inch you gain in Rim size decrease the sidewall height (series) 5 points and you will still have the same size when all said and done.
Old 06-28-2002, 08:35 PM
Yeah i got it thanks
Old 06-28-2002, 08:39 PM
:smoker2: Not a prob! I do have one question for you though. Do you know of any things to look out for when lowering a car by yourself except for the tension of the springs?
Old 06-28-2002, 10:00 PM
ECTurboGSX ECTurboGSX is offline
Send a message via AIM to ECTurboGSX
Incorrect info
That isn't exactly correct. There are three numbers in a tire size. The first number is how wide the tire is. This is an independent number, and is measered in mm (i think). A stock RS tire is 195 wide. But, you have a GS, and your stock width is 205. The stock tire on a GS is 205/55/16. The second number in the series is your sidewall profile. This is a DEPENDENT number, and is a ratio to the first number. Therefore, a 205/55 will have a shorter sidewall when compared to a 225/55. This is why the above info is incorrect. This is assuming that you keep the same width on the tire, which won't happen with 18s. The stock GS wheel is only 6 inches wide, where the 18 will be between 7 and 8. DO NOT GO WIDER THAN 8 INCHES ON THE WHEEL. Your optimum tire size for an 18x7 would be 225/35/18. Also, from what I have seen, the RS rolling diameter is smalled than the GS and above. For the RS at an 18, you would use a 215/30/18. The best way to do it is to find a rolling circumfrance calculator. I know one of the big Miata sites has one, but I don't remember the addy.
Eric
1990 Mitsu Eclipse GSX
13.4 @ 102.9
Big 16G @ 19 psi
Old 10-11-2002, 11:10 AM
nismo4banger nismo4banger is offline
Send a message via Yahoo to nismo4banger
calculator
www.miata.net/garage/tirecalc.html
This is a helpful tire calc.
Old 10-18-2002, 09:58 AM
turboracergsx's Avatar
turboracergsx turboracergsx is offline
Send a message via AIM to turboracergsx
18's with an eihbach sportline dropping 1.3 inches looks bad ass.
1998 GSX-K&N intake,Custom cold air box,Greddy type-s,Tokico illumina suspention,1.75" drop,Khumo ecsta 712's,Purple neon under car kit,Dejon tools uicp,Dejon tools intake pipe,Magnacore 8.5 plug wires.
18" rims yaheardbish Tires and Wheels 2 02-15-2002 02:35 PM
Differences between 17" and 18" rims BoosterSH Tires and Wheels 1 02-11-2002 07:35 PM
Motegi 18" rims and tires 99Eclipse Tires and Wheels 1 11-28-2001 12:09 PM
