Old 12-14-2005, 08:25 PM
Beef66 Beef66 is offline
grinding...
well this has been happening on and off for a while but tonight was the worst so far. It randomly starts to do this sometimes. Tonight i left and all was fine then I went to sheetz, when i went to leave it didnt want to go into reverse very easily, or any other gear. I kinda had to force it into gear or put it into it super softly...and 3rd sometimes grinds, 3rd also does this "double click" thing(dont know how to explain it) Why would it be doing this?
-Josh
Old 12-14-2005, 09:13 PM
Gateway's Avatar
Gateway Gateway is offline
Re: grinding...
could be your synchros or blocking rings
'92 3000GT VR4
Current Mods:
K&N FIPK
RPS Streetmax clutch
Rebuilt tranny
Free Boost Mod
Maximal Performance Solid Motor Mounts
Pictures and Videos of my car
Got a question about your auto insurance? I'm an insurance agent, ask away.
Old 12-14-2005, 09:41 PM
im really hoping its not the syncros but what are the blocking rings??
Old 12-14-2005, 09:44 PM
Gateway's Avatar
Re: grinding...
they are in the tranny with the synchros. they really aren't all that expensive to replace, if you can find a mechanic friend that doesn't rape on the labor.
'92 3000GT VR4
Current Mods:
K&N FIPK
Rebuilt tranny
Free Boost Mod
Old 12-15-2005, 02:02 AM
WReX WReX is offline
Re: grinding...
i would get it checked out ASAP, my girlfriends trans just took a dive two weeks ago and those were the symptoms, it was a '93 SL, she needed a full rebuild...$$$
26 PSI anyone?
Old 12-15-2005, 04:39 AM
Linebckr49's Avatar
Linebckr49 Linebckr49 is offline
Send a message via AIM to Linebckr49
Re: grinding...
before you freak out about a potential internal transmission problem, you might check the clutch and the slave cylinder first...more common problems. if the slave cylinder is gone or is about to go, then it will be hard to get into gear sometimes.
93 3000GT base
K&N | long tube headers | 3sx crank pulley| testpipe | Addco front/rear sway bars (3SX) | rear strut bar & front 3-point strut bar (by JonVr4 on 3Si) | solid motor mounts | LSD insert | KYB GR-2 struts | intrax springs | adj. control arms | ss brake lines | 16% taller 5th gear (teamrip.com) | H4 conversion | push-button start | datalogger | HKS S-AFR | PLX WB O2
coming soon: adj. cam gears | bi-xenon HID retrofit
Old 12-15-2005, 05:59 AM
how would one go about checking these things?
Old 12-15-2005, 10:20 AM
well The more I look into this it seems like its the slave cylinder, so I think im gonna replace it...I looked up how to do it and it doesnt seem all that hard but any tips from people would be appreciated. Also a friend of mines uncle owns a transmission shop/clutch shop so if it goes down hill i should be getting a goo deal
Old 12-15-2005, 11:52 AM
Morphius289's Avatar
Morphius289 Morphius289 is offline
Re: grinding...
Hmm, I was looking into replacing the slave cylinder, but I have no idea what to do. Does anyone know how much it should cost?
Black 1997 3000GT
Originally Posted by Igovert500
[01:05] Igovert500: scrwe his method
[01:05] Igovert500: too much crap
[01:06] Igovert500: i just jam a garden hose in there
[01:06] Igovert500: and put it on high flow
[01:06] Igovert500: go the opposite direction too
[01:06] Igovert500: so it clears out more shit
18 and out of debt - member #1
Old 12-15-2005, 12:47 PM
they have them for $60 on 3sx and directions on stealth316.com
Old 12-15-2005, 01:01 PM
Mikelb's Avatar
Mikelb Mikelb is offline
Send a message via AIM to Mikelb
Re: grinding...
damnit... I just had about posted the directions to replace the MASTER cylinder... then I caught myself... anyway... here's how to do it...
look on the back of the transmission (close to the firewall)... there will be the slave cylinder... simply use flare nut wrenches (10 mm) to unbolt the lines... there'll be two bolts holding the cylinder to the transmission... unbolt... put the new cylinder back into it's place... (first u gotta insert the piston)... bolt it back on... then reconnect the hydraulic lines... then bleed... presto...
(oh yeah, I assumed that you already removed the intake piping, or the cold air intake)...
Originally Posted by Blackcrow64
I write a lot... I wrote one song about this chick I was messing with that was uhhh... Well, lets just say I called it "Forbidden Love"
1991 Eagle Talon TSI - Broken
Head removed, block broken, trans in hatch
1991 Eagle Talon TSI AWD- in pieces
3" exhaust, rebuilt bottom end
Project: Assemble the Eagle is underway... and now with AWD
2003 Lancer Evo 1630hp/1593ft lb tq
Old 12-15-2005, 01:10 PM
Mikelb's Avatar
Re: grinding...
oh yeah, whatever u do... Make sure you don't let any brake fluid get on painted surfaces... or at least clean it ASAP... or your paint will peel... I've made that mistake before...
Old 12-15-2005, 04:42 PM
Linebckr49's Avatar
Re: grinding...
to replace the slave cylinder is quite simple, as Mikelb explained up above. when i dropped my transmission, i had to partially remove the slave cylinder, and the one difficult part about it was getting a 10mm wrench into the small space to remove/reinstall the bolts holding it on.
other than that, it shouldn't be too time consuming. maybe take you an hour tops. just make sure to put more fluid back in the system when your done and BLEED it. you'll need a second hand to help you bleed the clutch. follow direction on stealth316.com.
93 3000GT base
Old 12-16-2005, 11:51 PM
well when i got home from school today I checked my clutch fluid level, couldnt even see any fluid what so ever, so it was obviously really low, so I added some (took a good bit) and started her up, now i cant get in gear what so ever. Do i need to bleed my clutch to get it flowing right??
I think that was my problem, i wanted to do it when i got off work...but i didnt get off til 12:30 so im doing it really really early because i have to be back at work at 8 am
Old 12-18-2005, 10:27 AM
Streetwarriorz Streetwarriorz is offline
Send a message via MSN to Streetwarriorz
Re: grinding...
Bleeding the clutch would be a very good way to go!!
Take ya time doing it ie.don't rush. and remember to keep topping the resiviour up every so often or you'll have to start all over again!
GTO TT - More power than GOD
K&N Filter
Stainless hiflow Downpipe
Stainless hiflow Turbo elbows
Stainless hiflow Manifolds
Jamez 3" catback dual exit
Boost @ 1bar
Stock turbo's
