Old 12-14-2005, 03:12 PM
Milocka Milocka is offline
Red face Thromostat / temp sensor
does anyone know where the "coolant temperature sensor" is on an 02 Trailblazer? Code P0128 is in my OBD-II, and it means the temperature sensor is measuring coolant temperature below what the thermostat is regulating. Looks like i need a new temp sensor... I bought a new thermostat just in case that does not fix it, but the thermo is burried behind the power steering pump (BTW... THANKS GM!)
Where is the coolant sensor?
Thanks!
Old 12-21-2005, 06:52 AM
GunnerMac GunnerMac is offline
Re: Thromostat / temp sensor
Thanks!
Sorry, have no answers for you as I may have a similar problem. Was wondering why my 02 TB was not really heating up. This AM, it only got up to about 160 degrees while driving on I95 and the Check Engine Light eventually cam on. Noticed the heater was not blowing really hot for the past few days. Haven't had a chance to look into it yet - don't know if it is the thermostat or some sensor?
Old 12-22-2005, 12:20 PM
slynn1999 slynn1999 is offline
My Trailblazer is only heating up to about 130. I've read that it might be the Coolant Temperature Sensor, but I'm not sure where that is. I tried taking the Thermostat off to replace it, but ran into 2 problems. Advanced Auto Parts gave me the wrong part and I have no idea how to get the thermostat off. Please Help.
Old 12-22-2005, 12:58 PM
The top bolt for the thermo housing is easy, but the bottom one is behind the power steering pump. you have to remove the serp belt, the PS pump, and then you can get to it. Its not too fun. good luck.
Old 12-22-2005, 01:16 PM
GMMerlin's Avatar
GMMerlin GMMerlin is offline
I know stuff
Before replacing the sensor, you need to check the basics.
Is the cooling system full?
Most likely one of two senerios have taken place.
The thermostat is stuck open not allowing the engine to reach operating temperature or its extremely cold and the engine is not warming up as fast as the PCM wants.
Why do you never have enough time or money to do the job right the first time, but enough time and money to do it again?
Got all the certifications
25 years ASE Certified Master Technician
GM WCT
Yea..I work at a DEALERSHIP....got a problem with that?
Want to diagnose cars like the Pros? FOR SALE: OTC Perception 2 channel Labscope (badged as a Matco Reality)
This is my personal labscope that I use to diagnose waveforms, like new, comes with leads and training video
PM Me for details
Old 12-22-2005, 01:20 PM
Did you fix yours, How long did it take? Was it the sensor or the Thermostat? My Service Engine Light is also on.
Old 12-22-2005, 01:31 PM
Angry Re: Thromostat / temp sensor
mine is fixed, dont know which one it was because both the thermo and temp sensor were replaced. had a local shop do it, (didnt want to rip out the PS pump). your SES light is probably on due to code P0128. goto Autozone, they will check it for FREE.
Hopefully i am done with electrical issues! probably not though...
Old 12-22-2005, 01:54 PM
If you don't mind me asking, What was the cost? Did you have them buy the parts or did you supply them?
Old 12-22-2005, 02:13 PM
i supplied the parts ($25-thermo $17-sensor) and the laber was 1.4 hours... $154 for all.
Old 01-16-2006, 08:46 PM
I have one more question. I went to advanced auto parts to buy the thermostat, they sold me one that didn't fit. I took it back and they had nothing to fit it. They told me it wasn't an aftermarket part and that I would have to go to the dealer to buy it. Is this true, did you buy yours from the dealer?
Old 01-17-2006, 08:23 AM
NAPA - $30 or so... Make sure you get the one with the seal. here's a link:
http://www.napaonline.com/masterpage...ure+190+Degree
Old 01-21-2006, 11:00 AM
It looks like the same one I got from Advanced Auto Parts. It doesn't look like it will fit. My thermostat makes a 90 degree turn towards the front, this doesn't.
