Old 12-14-2005, 03:35 PM
chgoguy74 chgoguy74 is offline
Send a message via AIM to chgoguy74
Need more info on Fuel Economy and General Maintenance list
I just read the thread on tips for better fuel economy and general maintenance items, and I have some questions I was hoping I could get some help on.
For instance....
replacing the PCV valve > what is it? where is it located?
Transmission flush & refill & filter > How do I do that? What are the dangers/concerns?
Differential fluid > same questions...
O2 sensors / Thermostats / MAF > where can I find those?
Also, I have a '98 blazer 4dr... I'm having problems with it starting in extreme cold, like below 15-20 degrees. I replaced the battery and put some HEET in the tank, but I still got issues. If it's 20 degrees or above, she starts right up. Below that, and she cranks, but doesnt completely turn over. In fact, if she's been sitting a while, she'll start up, then immediately die. Then she'll crank and crank. I've been lucky enough to finally get her started, but I wasn't so lucky one day (the day I replaced the battery).
A friend said it might be the cold start sensor, and I've been looking in here for that solution, but I've yet to find it. I've seen where fuel pressure may be an issue, and I'm going to try and check that this weekend... I'm planning to change my fuel filter as well.
I'm in Chicago, and the weather just started getting cold...
You guys have some great advice.. keep up the good work!
Old 12-14-2005, 07:25 PM
OverBoardProject OverBoardProject is offline
Banned
Re: Need more info on Fuel Economy and General Maintenance list
All excelent questions, that we should probably include in that sticky.
And welcome to Automotive Forums
It's located on a valve cover. It's usually an L shaped object with a fuel hose sized hose going to it
Make sure that you get the right oil, and the right filter. Get a new gasket as well
The bigest hastle here is that you'll have to work under the truck for most of the job, and there isn't a drain plug. It can be a messy job if you mess up.
Loosen all the transmission pan bolts, then remove 1 side completely.
Slowely loosen of the side bolts, and start removing them as the pad slowely tips draining the oil out.
Remove the pan, the old filter, make sure that it's the same as the new filter. Clean all the surfaces, Then reverse the order using the new parts suplied. Fill this through the transmission dip stick tube.
Basicly the same as transmission.
O2 sensors
In the exhaust pipe. There might be 1 or 2 or more depending upon the year.
It's a sensor in the exhaust with a wire going to it.
Thermostats
Top of the motor, You'll see the round housing with a sleave that the top rad hose bolts into. Change your rad cap to a Stant brand. Unless it's already a stant.
MAF
Good question, my truck is to old, and doesn't have 1 so I don't know
Your truck starts fine until the other vehicles start having their problems with the cold as well. A tune up will help a little, but you might have to install a block heater to ensure that it'll start.
A block heater goes into one of the frost plug holes, and you plug it in.
This heats the water in the block just enough to keep it starting easily.
With some the block will be warm to the touch.
Good Luck
Old 12-14-2005, 07:28 PM
dmbrisket 51's Avatar
dmbrisket 51 dmbrisket 51 is offline
Send a message via AIM to dmbrisket 51
welcome to af... moter size, type of transmission (manual or auto transaxil) and year of vehical (also 8th vin charicter) and sorry, dont mean to offend, but if you need help to find a positive crankcase valve (pcv) you realy shouldnt be attempting a tranny or pig (rear end) service... the maf doesnt get replaced unless its bad, its a fairly expencive part that just gets cleaned... and its between the air box and the cpi unit or throttle body, depending on fuel delivery style... o2's, there are 4 on 96 and newer, one on each downpipe bank, one behind the y, and one behind the cat... t stat is in the housing at the block end of the top radiator hose, and finally the best advice i can give, if you do any work yourselfe, do not use Autozone, Advance auto, or any other bottum end parts store, dealer, napa, carquest is exceptable, but those places quality of parts is better then the quality of Autozone or Advance auto... hope ive helped and no offence ment by the tranny service and rear end, but they are kinda importent parts that if you screw the hootch on, WILL get expencive in a heartbeat
Old 12-14-2005, 07:39 PM
when doing a tranny service be sure to not let any rag materieal come in contact with the valve body (insides) this can wreck your transmission, and i (as a tech) do not reccomend transmission flushes, just a pan dorp and refill, and also, the tranny gasket from the factory is cork, i reccomend the extra $$ and putting a rubber one on instead of a new cork one, and when dropping the pan, make sure you clean the pan out, get the magnet back to where it belongs, and clean the gasket serfice on the pan and the tranny... and the magnet on the cover of the pig is glued in place, dont remove it from where it sits, and depending on year, the pig may require full synthetic fluid to go into it
Banned
DM is right.
I don't mind servicing my differentials, but I like to let a transmisssion shop service the transmission.
They pump all the junk out.
Don't just go to a Mr Lube type place. They just pump the old fluid out, and the new fluid in leaving an old probebly dirty filter in there.
Old 12-14-2005, 07:55 PM
your right obp, they leave old filters in and they get out of it legally becauce the 'flushed your system' a filter change is not something they do, and it is pointless to change the fluid and leave a shitty filter in, think about it, you replace your Napa gold or silver (wix is also fine) oil filter every time you change the oil, why would you change the transmission fluid and not get the filter with it?!?!????
Old 12-14-2005, 08:35 PM
blazee's Avatar
blazee blazee is offline
Problem?
On a 98, the PCV valve is in the driver side valve cover.
My 98 has three O2 sensors, one at each manifold, and one after the cat.
The recommended intervals are a little off in that thread. Transmission service should be done every 30,000 miles. (15,000 for special duty applications) or 2 years. The recommended interval for O2 sensors is 100,000 miles.
Old 12-14-2005, 08:44 PM
that is weird, my 98 has 4, hm, looks like i got the 'high matnence' modle
Old 12-14-2005, 08:54 PM
blazee's Avatar
Problem?
I've heard a few others say that they had 4 O2 sensors, too. I have yet to figure out why some would have 3 and others have 4, there must be some reason.
Old 12-14-2005, 09:00 PM
8th vin is a?
Old 12-14-2005, 09:13 PM
blazee's Avatar
Problem?
It's got the standard Blazer engine vin "W". The Blazers aren't like the pick-ups where you see both "W" and "X" regularly........ now that I think about it, I don't think I've seen a second gen Blazer with anything other than a "W".
Old 12-14-2005, 09:31 PM
i beleve you could get the 2nd gens with an x back in the cpi days, but dont quote me on it
Old 12-14-2005, 09:34 PM
blazee's Avatar
Problem?
Re: Re: Need more info on Fuel Economy and General Maintenance list
Oops, too late. I already quoted you.
Old 12-14-2005, 09:40 PM
lmao!
Old 12-15-2005, 10:46 AM
Thanks for the welcome, and no offense taken on the pcv comment. I'll probably leave the first tranny flush to one to my mechanic friends and get an idea of how much is involved. The reason I ask about concerns/dangers is I've heard there may be a sensor of some sort on the tranny that can be damaged, but I haven't seen it mentioned anywhere.
I apologize for my ignorance, but I've never had the time, schooling, or vehicle to play with so a lot of this stuff is new to me. This is my first truck, and it's gotten to the point where its needing some major services done, and I'm tired of paying for it when I can do most of it myself. I do have some common sense and ability though, so I'll get a haynes manual and do what I can....
I've got a 98 blazer, 4 dr, 4.3l automatic, 8th vin char is a 'dubya'...
1 last thing.. is there a cold start sensor on this truck?
