Go Back   Automotive Forums Car Chat > GMC > Yukon
Old 12-14-2005, 01:22 PM
TTU TTU is offline
Back Doors Squeak
I have an '01 Yukon SLT (Well technically it's not mine until Feb. when my mom gets a new car) Anyways the back doors squeak when opened and closed. I tried spraying WD-40 on the hinges and it did nothing. Is there a way to fix this? (I think it's a common problem because my friends '02 Tahoe does the same thing)
Old 12-14-2005, 01:36 PM
2000CAYukon 2000CAYukon is offline
Re: Back Doors Squeak
The squeak occurs where the door hit the weather stripping at the top. On mine, I rub dielectric grease with a rag into the weather stripping. I probably do this twice a year.
//2000CAYukon
Old 12-14-2005, 02:07 PM
TTU TTU is offline
Re: Re: Back Doors Squeak
//2000CAYukon
Where can I get some of this dielectric grease?
edit: Is this what I need?
http://www.homedepot.com/prel80/HDUS...gll.0&MID=9876
I don't think the link is working, but just go to home depot and type dielectric grease in the search bar...Here's the pic it shows
Old 12-14-2005, 04:14 PM
Re: Re: Re: Back Doors Squeak
I got mine at the local auto parts store. If you take a look at your owners manual, it will list the GM equivalent for using on the weather stripping.
//2000CAYukon
Old 12-14-2005, 08:50 PM
Bevl Hvn's Avatar
Bevl Hvn Bevl Hvn is offline
rubber care
+1 what he said. I lube up the top weatherstrip as well as all the other bits or rubber with 3M vinyl & rubber cleaner. Works a treat.
Dielectric grease works REALLY great in all electrical junctions to keep corrosion from happening and I use the stuff all the time
Old 12-14-2005, 11:09 PM
TTU TTU is offline
Re: rubber care
Wait, so what do I put on the rubber weather things? dielectric grease, 3M Vinyl, or Rubber Cleaner?
Old 12-14-2005, 11:48 PM
In my owner's manual (Section D: Recommended Fluids and Lubricants) it has:
For Weatherstrip use Dielectric Silicone Grease (GM Part No. 12345579 or equivalent)
For Weatherstrip squeaks use Synthetic Grease with Teflon, Superlube (GM Part No. 12371287 or equivalent).
I have always used Dielectric Grease but you may want to try the synthetic grease with Teflon.
//2000CAYukon
Old 12-15-2005, 08:07 PM
pbsfolks pbsfolks is offline
I had the same problem with my 2001 SLT, Service rep @ my local GMC store had the hinge pins replaced while I was still under warranty, nothing else worked, I tried em all before seeking his advise, now...no squeaks, Good Luck.........Mike
Leave that alone!!!! it'll grow on its own
