Go Back   Automotive Forums Car Chat > Saturn > SC/SL/SW
Old 12-14-2005, 11:33 AM
autumnsunn autumnsunn is offline
Send a message via Yahoo to autumnsunn
Wink Window Problems (1998) Saturn 2 door
My window is completely offtrack somehow. First of all, how do you get the door apart? Secondly, how do you get the window back on track for good? The motor is in perfect condition, I don't know what happened to the window. Please help.
Thank You in advance.
Old 12-14-2005, 11:37 AM
HAWG HAWG is offline
Re: Window Problems (1998) Saturn 2 door
remove the outer door panel to gain access to the regulator. the black plastic guide has probably broken that holds the window in the track
Old 12-14-2005, 12:18 PM
saturnspeed_12's Avatar
saturnspeed_12 saturnspeed_12 is offline
ok first pop the mirror cover off. its held on by clips. next remove the screws, one at bottom, 2 on bottom of handle and one behind door lever. now im sure you have power door locks, so pry at the top of the switch. most have a notch at the top and unplug connector. now you should be able to access the clip that holds the rod on the door lever, you need to pull the entire cup out a bit in order to pop the clip off. its just a plastic piece that rotates and clips onto the rod, i think its white. now just lift up on the door panel to get the upper lip of the panel off the door. do not pull out on it, just lift up till its come loose.
Old 12-14-2005, 01:37 PM
Re: Re: Window Problems (1998) Saturn 2 door
Thank You for the input. I'll check it this weekend.
Old 12-14-2005, 01:41 PM
Smile Re: Window Problems (1998) Saturn 2 door
You have no Idea how much help this is. Thank you so much!
