Go Back   Automotive Forums Car Chat > Toyota > Sienna
Old 12-14-2005, 10:45 AM
crazyinmebane crazyinmebane is offline
air flow meter
i have a 2001 sienna haven't had any problems with it except about 2 months ago had to have the air flow meter replaced ended up spending about $300 when all was done. does anyone know what the life expectancy of an an flow meter is?thanks.
Old 01-16-2006, 12:08 PM
Brian R.'s Avatar
Brian R. Brian R. is offline
Resident Chemist
Send a message via Yahoo to Brian R.
Re: air flow meter
Better off posting in the Sienna forum - moved
Forum Guidelines:http://www.automotiveforums.com/vbulletin/guidelines.html
"What we've got here is a failure to communicate"
Old 01-26-2006, 02:30 PM
Doug Tatham Doug Tatham is offline
Re: air flow meter
I found a MAF for 2001 Sienna on line for $108.78.
It takes about 20 minutes to install if you are a novice using common tools.
The MAF on my VW jetta is 15 years old and still works fine. They do get dirty though. A bit of carb cleaner usually does the trick.
As far as whether or not your were overcharged, that's up for you to decide.
