Go Back   Automotive Forums Car Chat > Mercury > Cougar
Old 12-14-2005, 10:39 AM
EeyoreMarv EeyoreMarv is offline
Shift Lever Interlock
On a 1997 Cougar, automatic transmission. Does anyone know if, there is a shift lever, manual release button ??? If so, where and how to find it. Thanks
Old 12-14-2005, 10:49 AM
JR Tigerstar's Avatar
JR Tigerstar JR Tigerstar is offline
Re: Shift Lever Interlock
The only "button" is on the left side of the shifter handle.
You do have to have the brake pedal depressed to shift out of "park".
What are you trying to do?
Old 12-14-2005, 01:04 PM
Re: Re: Shift Lever Interlock
When it is cold outside air temp., with the brake depressed, the button on the T-Bar will not depress, once the interior is warm it works very well. I have been told there is an over ride to allow you to shift out of park.
Old 12-15-2005, 12:08 AM
S Koehl S Koehl is offline
I had the same similar problem with 2 of my cars. The reason the shift lever button would work after the car was warm with one of my cars was because there was gunk inside where the spring mechanism is, it was easy to take apart and clean. (probably spilled coffee at some time or another) but the heat would losten up the syrupy gunk so that the button would depress but when cold it dried like cement. I don't know if there is an over-ride button but why not try taking it apart and cleaning it to see if you have a similar problem?
Old 12-15-2005, 06:11 AM
Thanks, that is what has been suggested by others. Also the shift interlock actuator, (Solinoid), mat be gummed up and needs cleaning. Thanks for the help.
