Go Back   Automotive Forums Car Chat > Chevrolet > Caprice
Old 12-14-2005, 09:54 AM
mackamitsu mackamitsu is offline
Send a message via MSN to mackamitsu
gas in the oil
Hi guys,
I'm stumped, I am getting gas in the oil, I replaced the intake gasket, and the head gaskets. I torqued them down, ran them and checked the torque after an hour of idling. It's a 307, any ideas????
Old 12-14-2005, 10:37 AM
silicon212's Avatar
silicon212 silicon212 is offline
Confoundingly Lucid
Send a message via ICQ to silicon212
Re: gas in the oil
Replace your fuel pump.
Old 12-14-2005, 11:43 AM
bobss396's Avatar
bobss396 bobss396 is offline
Send a message via AIM to bobss396
Sounds like too much fuel to me. Look for a stuck carb float or leaky float bowl plug.
Old 12-14-2005, 12:16 PM
ok I'm checking those things tonight, thanks for helping me unfreeze the brain
Old 12-14-2005, 01:58 PM
1986Z28's Avatar
1986Z28 1986Z28 is offline
Has a Camaro
Send a message via MSN to 1986Z28
Re: gas in the oil
i was getting oil in my old caaprice with the 307, but it had really bad rings
Formerly Blownalcoholboy
1986 Z28, 400ci SBC, Twin borg warner billet S467 turbos, Reid case powerglide, Moser 9". Holley EFI, Boost Leash. 950RWHP on pump gas, 1200rwhp on race gas (22 psi)
Best ET 1/4: 8.35 @ 170mph (275 drag radial)
Best ET 1/8: 5.44 @ 132mph (275 drag radial)
Best 60': 1.31 on the back tires (275 drag radial)
AF User Rules/Guidelines
http://www.automotiveforums.com/vbul...uidelines.html
Old 12-14-2005, 05:42 PM
PeteA216's Avatar
PeteA216 PeteA216 is offline
Send a message via AIM to PeteA216
Re: gas in the oil
While we're on the subject of oil, and things that shouldn't be mixed in with it, what does it mean when you get a tan colored foam on the oil dipstick right after shutting off the engine?
Old 12-14-2005, 05:55 PM
Re: Re: gas in the oil
what does it smell like?? mine was a light tannish colour and smelt of gas, and it was the fuel pump. I am going to pull the carb on Saturday though, seeing this beasty was sitting for a season.
Old 12-14-2005, 07:03 PM
silicon212's Avatar
Confoundingly Lucid
Re: gas in the oil
light tannish oil is presence of coolant in the oil - not good - poss blown head gasket, warped heads or cracked head/block. Most likely head gasket and warped head - has it overheated lately?
Old 12-14-2005, 08:45 PM
1986Z28's Avatar
Has a Camaro
Re: gas in the oil
coolant in oil is bad, but he says he smelt gas
Old 12-14-2005, 10:02 PM
silicon212's Avatar
Confoundingly Lucid
Re: gas in the oil
If the engine has high mileage on it, then blowby can cause the fuelish smell - tan oil is ALWAYS water and/or coolant. Gasoline in oil will thin the oil, but not discolor it. Oil with a lot of gasoline in it will have a solvent-like quality to it - hard to explain, you'd know it when you saw it. Aside from rust issues with water and the lack of lubricity it poses, coolant is acidic and will take out the bearings if you wait too long.
Aside from thinning the viscosity and possibly causing premature breakdown (which in itself is bad news), a little gasoline in the oil will not pose too much of a problem, and assuming the flow can be stemmed, will evaporate from the oil.
Regarding my original comment about the fuel pump above - the mechanical fuel pump presents the largest opportunity for raw gasoline to enter the crankcase - it's happened to me. The only other way that gas can enter the crankcase in fairly large quantities would be from seriously flooding a carburetor.
Old 12-15-2005, 06:38 AM
bobss396's Avatar
I hadn't thought of the fuel pump, a good place to start. Especially if the motor has been sitting for a while. They're pretty cheap and easy to change. Once you have it out you can tell if that's the source of your gas inlet.
Bob
Old 12-15-2005, 07:04 AM
Re: gas in the oil
Bob
Yea it was the pump , could see where the little gasket going to the arm should have been. Changed the oil, going to let it idle today for a while, and see if we get the other issue, the old intake and head gaskets were pretty dry, the new ones aren't, so we'll see how it goes. Hopefully I can score a set of 5A heads.
Old 12-15-2005, 10:25 AM
PeteA216's Avatar
Re: gas in the oil
Im glad that the fuel pump was ur problem, it made a lot of sense. As to answer the questions above, my engine has 72K on it. No it hasnt overheated at all in the 3 years I've owned it. The oil doesnt have much of a smell to it, but every once in a while while driving, or after i shut off the car and get out I can small burning antifreeze, but I can't find any leaks or steam coming from under the engine compartment.
My father suggested that since my PCV valve was replaced with abreather, air isnt properly being pumped through the crank case and condensation is building up inside causing the tan color in the oil. Is that even possible?
Old 12-15-2005, 10:37 AM
silicon212's Avatar
Confoundingly Lucid
Re: gas in the oil
Not generally, but there is another possibility I didn't think of earlier - if that has the factory intake on it then it's made of aluminum. These often corroded and allowed coolant into the oil. Places to look are the back of the engine where the water ports on the heads would be, as well as any obvious sign of corrosion anywhere on the intake near a water passage.
bobss396's Avatar
Pete, I think you should still run a PCV valve. You could be getting a condensation build up, look at your oil fill cap too. You might see a light build up on it.
I used to get an antifreeze smell on my '84 once in a while. I believe it is the heater core. I dumped in a vial of those silver crystals which stopped my coolant loss, I do get a very slight whiff now and then still.
You could still have a head gasket leak, dump in a can of Solder Seal Block Saver. Older auto parts stores carry it, you usually have to ask for it. Also pressure check your system if you have a tester, or borrow one. It should show anything like a hose, thermostat housing, heater control valve leak, also maybe the heater core.
Bob
