Old 12-14-2005, 07:20 AM
strotma strotma is offline
intercooler
Do I really need to install an intercooler running a 3.0 pulley?
If so what brand? And how hard to install.
Thanks
97gtp 3 on tranny 14,000 on engine
Goodyear Gatorback
Thrasher Individual Pulley 3.25
Digital Horsepower Inc. v1.0 PCM for Grand Prix GTP
Rollmaster Roller Timing Set Double
Comp Cam Xtreme Energy L67 Cam 1
Genuine GM LS6 Valvespring
Comp Cams Valvespring Retainers
Comp Cams Hi-Tech Pushrods
The Other Guys Exhaust Header Ceramic Coating
Borla Stainless Steel Cat-Back Exhaust System
K&N AirCharger Performance Intake Kit
Engineered Performance Race Transmission 3.29 High Torque Input Shaft
Pirelli P6 tires
Quick Time Electric Exhaust Cutout
AutoLite Copper Core Spark Plugs (3 heat ranges)
180 thermostat
Old 12-14-2005, 07:45 AM
BNaylor's Avatar
BNaylor BNaylor is offline
Re: intercooler
With your current mods, what amount of knock retard (KR) are you seeing?
Timeslip 08/12/06
AF Community Guidelines
Old 12-14-2005, 02:03 PM
Re: Re: intercooler
Right now no KR at all.
Old 12-14-2005, 02:26 PM
BNaylor's Avatar
Re: Re: Re: intercooler
Thats good. Our mods are similar less the racing tranny and cam. I've heard that going to an intercooler with a 3.0 or less pulley is recommended but not mandatory. I know guys locally running 3.0 and 2.8 pulleys with no intercooler. But IMO it is based on KR, if any. In your case it probably wouldn't hurt to go for it. After the mod just double check the KR again. The other item recommended is going to the next size up fuel injectors on the smaller 3.0 and less pulleys.
If you decide to install the 3.0 pulley let me know how it turns out. I might get one too. I've got a modular pulley system so the swap out is very easy. Good luck!
Timeslip 08/12/06
Old 12-15-2005, 07:02 AM
I'll try 3.0 this weekend. Then Scan Scan Scan. . I don't know if I need a smaller Gator or not. I'll let U know
Thanks--- bnaylor3400
Old 12-15-2005, 07:08 AM
BNaylor's Avatar
Re: intercooler
No problem and you are welcome. Here is a guide for the GY Gatorback SC belt:
- 4060660 belt = 3.25” - 3.4” pulleys 66.0" long
- 4060650 belt = 2.9” - 3.1” pulleys 65.0" long
- 4060642 belt = 2.7” - 2.85” pulleys 64.2" long
Good luck!
Timeslip 08/12/06
