Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 12-14-2005, 12:02 AM
Chris8989 Chris8989 is offline
Unhappy rough idle help!?
I have a talon 1995 tsi auto, changed plugs, wired, stepper motor, tune up, fuel maintenace, synthtics. When i first start the car the idle will never drop until I put it in gear. Then, especially when its cold out, it has serious rough idle, almost like vibrations in the dash and steering wheel. Sometimes it feels like the car is off at lights (perfect) most times it feels like a deisel when at a stand still. I have a throttle body sensor from a Stealth but cant seem to get the lower screw off in the talon. ANy suggestions?
Old 12-14-2005, 10:24 AM
ez1286's Avatar
ez1286 ez1286 is offline
Send a message via AIM to ez1286
Re: rough idle help!?
Could be your mas I had a similar problem with my gsx. I'd try ebay first cause they're like $500 from the dealer
95 GSX:FMIC, 6-bolt, evo 3 16g, 2600 act clutch, 1g bov (crushed), and a 3" turbo back exhaust, dsmlink, dks 272 cams, wideband 02, Coming soon 2.3L Stroker, 1mm oversized valves, crower sprigs. 91 TSI AWD auto, gm 3.5 maf, maft, fmic, emanage, profec e-01, 3" turbo bk exhaust +more little stuff.
http://www.ratemydsm.com/member/ez1286/?member=ez1286
