Old 06-05-2002, 05:47 PM
onesojourner's Avatar
onesojourner onesojourner is offline
Send a message via AIM to onesojourner
i think my clutch is going (suggestions welcome)
well i got up today and drove to work my clutch pedal goes almost to the floor before it ingages. i mean prob about 1-2 inches before it hits the floor. i hope it will work its way out but i have a bad feeling it wont. i havnt been racing so i dont know what the deal is. So if im right in guessing my clutch has one foot in the grave what should i do. ive looked at ACT clutchMasters and excedy. all around 300 bucks. will and after market clutch last longer then a stock one. i want something that will last a long time. will the above clutches last as long as stock or longer with the same driving habits? any other good drands? are all these ok? and lastly what will it cost to put one in at a shop? is it something a normal person can do?
don't like my post
The things you own end up owning you-Tyler Durden
videos
Old 06-05-2002, 09:47 PM
Rice-Rocketeer Rice-Rocketeer is offline
Sounds like the brake fluid in the Clutch master cylinder reservoir is low. Try checking it and adding more as necessary.
Lookin at my gucci, it's about that time...
Old 06-05-2002, 11:36 PM
h82lose h82lose is offline
I think I have a problem with my clutch as well. Can you guys here your clutch when you push it in. It sounds very much like a old door opening or like when you jump on a old mattress. Also when you push it all the way down should it feel squishy. Like your mashing a bug. It only feels squishy all the way down.
Old 06-05-2002, 11:50 PM
It's normal for older cars, mine does it, it's a 95. As long as it grabs the way it's supposed to at the right pedal travel, it'll be fine.
Old 06-06-2002, 01:02 AM
Well mines a 96 cx hatchback. Now when I change the clutch this sound and feeling will go away?
Old 06-06-2002, 06:39 AM
JayFidizzy's Avatar
JayFidizzy JayFidizzy is offline
Banned
Send a message via AIM to JayFidizzy
Buy a clutch masters stage 3...
Old 06-06-2002, 01:54 PM
Ebranste Ebranste is offline
Send a message via ICQ to Ebranste Send a message via AIM to Ebranste
Well if you have a cable tranny, it sounds like it needs to be adjusted, other wise I'd expect you have a hydro tranny. If it's hydro, then definately check your clutch master clinder for enough fluid and if it bottomed out your gonna have to bleed your clutch to get the air out of the line. Otherwise, if its full, you may want to try bleelding it anyways.
Old 06-06-2002, 02:48 PM
j.fuggi's Avatar
j.fuggi j.fuggi is offline
got a clutchmasters stage 4.
once in a while it squeaks. but it catches almost all the way out.
» Supercharged 2006 Honda Civic Si Coupe
» Info | Teaser Video | Dyno Video | Dyno Graph
Old 06-06-2002, 11:28 PM
ok im a retard my master cylinder was empty so i filled it up and it works great
don't like my post
videos
Old 06-07-2002, 12:46 AM
You're welcome.
This is why it upsets me to see ppl automatically say "Get a stage 50 ACT". A little common sense and a manual will save you a lot of money.
Old 06-08-2002, 09:52 AM
Bryan8412 Bryan8412 is offline
Send a message via AIM to Bryan8412
Re: i think my clutch is going (suggestions welcome)
well you're definently in bad shape if your clutch engages near the floor...
mmmmmm.... :jump:
Old 06-08-2002, 10:41 AM
luti luti is offline
Send a message via AIM to luti
Be careful, those things don't drain for no reason. You might have a leak somewhere... Check it often so you don't get caught up the creek...
T3/T04E turbocharged ricer.
clutch problem..i think bov3220 Engine, Transmission and Drivetrain 4 05-22-2009 12:17 PM
Thinking about buying... suggestions jbanny 9000 0 02-13-2008 09:29 AM
Need new clutch...any suggestions YellowITR479 N2O | Turbo | Superchargers 6 06-05-2004 01:08 AM
